Installing Mac mini Model A1176 Speaker
  1. Installing Mac mini Model A1176 Speaker, Internal Frame: step 1, image 1 of 3 Installing Mac mini Model A1176 Speaker, Internal Frame: step 1, image 2 of 3 Installing Mac mini Model A1176 Speaker, Internal Frame: step 1, image 3 of 3
    • Later in this guide you will remove several recessed Phillips screws. Bit drivers are generally too large to fit in the recesses, so be sure to have a thin shafted Phillips screwdriver on hand.
    • First remove the AirPort antenna (the larger of the two), located near the power button.
    • Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
    • Squeezing the two posts excessively will surely break them off the internal frame. Work delicately.
    • During reinstallation, you will have to slightly squeeze the two posts together so they fit into the openings on the AirPort antenna board.
  2. Installing Mac mini Model A1176 Speaker: step 2, image 1 of 2 Installing Mac mini Model A1176 Speaker: step 2, image 2 of 2
    • Use the tip of a spudger to slightly lift the left side of the ZIF cable lock up from its socket.
    • The ZIF cable lock will lift about 1 mm and stop. Do not try to completely remove the ZIF cable lock.
  3. Installing Mac mini Model A1176 Speaker: step 3, image 1 of 1
    • Lift the audio board ribbon cable up out of its socket.
    • If it refuses to lift from its socket, the ZIF cable lock is not fully released. Make sure it is evenly lifted about 1 mm from the socket on the interconnect board.
  4. Installing Mac mini Model A1176 Speaker: step 4, image 1 of 2 Installing Mac mini Model A1176 Speaker: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Rotate the mini so that the SuperDrive slot loading mechanism is facing you.
    • Use a pair of tweezers to lift the hard drive thermal sensor cable connector up off its socket on the logic board.
    • Use tweezers to grab the connector (as seen in the picture), not the wires.
    • The connector is located under the optical drive opening, next to the PRAM battery.
  5. Installing Mac mini Model A1176 Speaker: step 5, image 1 of 2 Installing Mac mini Model A1176 Speaker: step 5, image 2 of 2
    • In the next few steps, you will remove the four Phillips screws securing the internal frame to the bottom case. Included in each step is an overview picture showing the general location and a closeup showing the actual screw.
    • Remove the recessed Phillips screw near the power button securing the internal frame to the bottom housing.
  6. Installing Mac mini Model A1176 Speaker: step 6, image 1 of 2 Installing Mac mini Model A1176 Speaker: step 6, image 2 of 2
    • Remove the recessed Phillips screw near the sleep light securing the internal frame to the bottom housing.
    • This screw is the longest of the four screws securing the internal frame to the bottom case.
  7. Installing Mac mini Model A1176 Speaker: step 7, image 1 of 2 Installing Mac mini Model A1176 Speaker: step 7, image 2 of 2
    • Remove the Phillips screw from the internal frame near the Bluetooth antenna.
  8. Installing Mac mini Model A1176 Speaker: step 8, image 1 of 2 Installing Mac mini Model A1176 Speaker: step 8, image 2 of 2
    • Remove the Phillips screw near the audio ports securing the internal frame to the bottom case.
  9. Installing Mac mini Model A1176 Speaker: step 9, image 1 of 2 Installing Mac mini Model A1176 Speaker: step 9, image 2 of 2
    • Gently lift the internal frame up from the bottom housing, minding the AirPort antenna and any other cables that may get caught.
    • It may be necessary to pull up near the interconnect board to separate it from the logic board.
  10. Installing Mac mini Model A1176 Speaker, Hard Drive: step 10, image 1 of 1
    • Remove the two Phillips screws securing the side of the hard drive to the internal frame.
  11. Installing Mac mini Model A1176 Speaker: step 11, image 1 of 1
    • Remove the two Phillips screws securing the bottom of the hard drive to the internal frame.
  12. Installing Mac mini Model A1176 Speaker: step 12, image 1 of 2 Installing Mac mini Model A1176 Speaker: step 12, image 2 of 2
    • Use your thumbs to slide the hard drive toward the speaker, disconnecting it from the interconnect board.
  13. Installing Mac mini Model A1176 Speaker: step 13, image 1 of 1
    • Maneuver the hard drive out of the internal frame.
    • During reinstallation, it may be helpful to move the cables away from the SATA connector and to hold the internal frame upside down (while supporting the hard drive) to help seat it in its connector.
    • Don't forget to transfer the foam padding to the new hard drive.
    • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
  14. Installing Mac mini Model A1176 Speaker, Speaker: step 14, image 1 of 1
    • Maneuver the metal bracket near the speaker out of the internal frame.
  15. Installing Mac mini Model A1176 Speaker: step 15, image 1 of 1
    • Remove the four Phillips screws securing the speaker to its metal bracket.
  16. Installing Mac mini Model A1176 Speaker: step 16, image 1 of 1
    • Disconnect the following connectors from the interconnect board:
    • IR sensor cable.
    • Fan cable.
  17. Installing Mac mini Model A1176 Speaker: step 17, image 1 of 1
    • Use a pair of tweezers or your fingernails to disconnect the speaker cable connector from the interconnect board.
  18. Installing Mac mini Model A1176 Speaker: step 18, image 1 of 1
    • De-route the cables from the channel in the internal frame until the speaker cable is free.
  19. Installing Mac mini Model A1176 Speaker: step 19, image 1 of 1
    • Lift the speaker out of the internal frame.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 7,180
