Installing Mac mini Model A1176 Fan
  1. Installing Mac mini Model A1176 Fan, Internal Frame: step 1, image 1 of 3 Installing Mac mini Model A1176 Fan, Internal Frame: step 1, image 2 of 3 Installing Mac mini Model A1176 Fan, Internal Frame: step 1, image 3 of 3
    • Later in this guide you will remove several recessed Phillips screws. Bit drivers are generally too large to fit in the recesses, so be sure to have a thin shafted Phillips screwdriver on hand.
    • First remove the AirPort antenna (the larger of the two), located near the power button.
    • Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
    • Squeezing the two posts excessively will surely break them off the internal frame. Work delicately.
    • During reinstallation, you will have to slightly squeeze the two posts together so they fit into the openings on the AirPort antenna board.
  2. Installing Mac mini Model A1176 Fan: step 2, image 1 of 2 Installing Mac mini Model A1176 Fan: step 2, image 2 of 2
    • Use the tip of a spudger to slightly lift the left side of the ZIF cable lock up from its socket.
    • The ZIF cable lock will lift about 1 mm and stop. Do not try to completely remove the ZIF cable lock.
  3. Installing Mac mini Model A1176 Fan: step 3, image 1 of 1
    • Lift the audio board ribbon cable up out of its socket.
    • If it refuses to lift from its socket, the ZIF cable lock is not fully released. Make sure it is evenly lifted about 1 mm from the socket on the interconnect board.
  4. Installing Mac mini Model A1176 Fan: step 4, image 1 of 2 Installing Mac mini Model A1176 Fan: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Rotate the mini so that the SuperDrive slot loading mechanism is facing you.
    • Use a pair of tweezers to lift the hard drive thermal sensor cable connector up off its socket on the logic board.
    • Use tweezers to grab the connector (as seen in the picture), not the wires.
    • The connector is located under the optical drive opening, next to the PRAM battery.
  5. Installing Mac mini Model A1176 Fan: step 5, image 1 of 2 Installing Mac mini Model A1176 Fan: step 5, image 2 of 2
    • In the next few steps, you will remove the four Phillips screws securing the internal frame to the bottom case. Included in each step is an overview picture showing the general location and a closeup showing the actual screw.
    • Remove the recessed Phillips screw near the power button securing the internal frame to the bottom housing.
  6. Installing Mac mini Model A1176 Fan: step 6, image 1 of 2 Installing Mac mini Model A1176 Fan: step 6, image 2 of 2
    • Remove the recessed Phillips screw near the sleep light securing the internal frame to the bottom housing.
    • This screw is the longest of the four screws securing the internal frame to the bottom case.
  7. Installing Mac mini Model A1176 Fan: step 7, image 1 of 2 Installing Mac mini Model A1176 Fan: step 7, image 2 of 2
    • Remove the Phillips screw from the internal frame near the Bluetooth antenna.
  8. Installing Mac mini Model A1176 Fan: step 8, image 1 of 2 Installing Mac mini Model A1176 Fan: step 8, image 2 of 2
    • Remove the Phillips screw near the audio ports securing the internal frame to the bottom case.
  9. Installing Mac mini Model A1176 Fan: step 9, image 1 of 2 Installing Mac mini Model A1176 Fan: step 9, image 2 of 2
    • Gently lift the internal frame up from the bottom housing, minding the AirPort antenna and any other cables that may get caught.
    • It may be necessary to pull up near the interconnect board to separate it from the logic board.
  10. Installing Mac mini Model A1176 Fan, Fan: step 10, image 1 of 1
    • Disconnect the following connectors from the interconnect board:
    • IR board cable.
    • Fan cable.
    • Due to their small size, it is helpful to either use your fingernails or tweezers to grab the connectors and pull them away from the interconnect board.
  11. Installing Mac mini Model A1176 Fan: step 11, image 1 of 1
    • De-route both the fan and IR board cables out of the channel in the internal frame.
  12. Installing Mac mini Model A1176 Fan: step 12, image 1 of 1
    • Remove the two Phillips screws securing the fan to the internal frame.
  13. Installing Mac mini Model A1176 Fan: step 13, image 1 of 1
    • Lift the fan out of the internal frame, minding any cables that may get caught.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 30,910
