Introduction
Replace a faulty audio board to regain audio out and microphone functionality.
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Use the tip of a spudger to slightly lift the left side of the ZIF cable lock up from its socket.
Remove the recessed Phillips screw near the power button securing the internal frame to the bottom housing.
Remove the recessed Phillips screw near the sleep light securing the internal frame to the bottom housing.
Remove the Phillips screw near the audio ports securing the internal frame to the bottom case.
Gently lift the internal frame up from the bottom housing, minding the AirPort antenna and any other cables that may get caught.
Remove the single Phillips screw securing the audio board to the bottom housing.
Use a spudger to depress the small metal finger (shown in red) while lifting the audio board with your thumb.
Lift the free end of the audio board slightly and pull it away from the port side of the bottom housing.
