Installing Mac Mini Mid 2011 Speaker
  1. Installing Mac Mini Mid 2011 Speaker, Bottom Cover: step 1, image 1 of 2 Installing Mac Mini Mid 2011 Speaker, Bottom Cover: step 1, image 2 of 2
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
    • You do not need to apply much downward pressure while turning.
  2. Installing Mac Mini Mid 2011 Speaker: step 2, image 1 of 1
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
  3. Installing Mac Mini Mid 2011 Speaker, Fan: step 3, image 1 of 1
    • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
  4. Installing Mac Mini Mid 2011 Speaker: step 4, image 1 of 1
    • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
    • Removing the standoff screw is not necessary to remove the fan. You need only raise the fan enough to lift it off the standoff screw.
  5. Installing Mac Mini Mid 2011 Speaker: step 5, image 1 of 3 Installing Mac Mini Mid 2011 Speaker: step 5, image 2 of 3 Installing Mac Mini Mid 2011 Speaker: step 5, image 3 of 3
    • Lift the fan out of the mini for enough clearance to access its connector.
    • Grab all the wires at once and gently pull straight up to disconnect the fan from the logic board.
    • Do not pry at the socket, or you may rip it from the logic board.
    • Remove the fan.
  6. Installing Mac Mini Mid 2011 Speaker, Cowling: step 6, image 1 of 1
    • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
  7. Installing Mac Mini Mid 2011 Speaker: step 7, image 1 of 1
    • Lift the cowling from the end nearest the antenna plate.
    • Rotate the cowling away from the outer case and remove it from the mini.
  8. Installing Mac Mini Mid 2011 Speaker, Antenna Plate: step 8, image 1 of 1
    • Remove the following screws securing the antenna plate to the mini:
    • Two 6.6 mm T8 Torx screws
    • Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either screwdriver will work)
    • When putting back together:
    • It can be difficult to get the hard drive seated correctly such that the antenna plate fits in place correctly. If the screw holes don't line up with those on the hard drive, make sure that the two pins that are in the back of the hard drive are properly seated in the holes at the back of the case, above the housing for the second hard drive.
    • The antenna attaches directly to the hard drive (red markers), therefore attaching the antenna can move the hard drive around and loosen the connection of the hard drive cable to the logic board.
  9. Installing Mac Mini Mid 2011 Speaker: step 9, image 1 of 2 Installing Mac Mini Mid 2011 Speaker: step 9, image 2 of 2
    • Slightly lift the antenna plate from the end closest to the RAM.
    • Carefully pull the antenna plate away from the circular rim of the outer case.
    • Do not remove the antenna plate yet. It is still attached to the AirPort/ Bluetooth board.
  10. Installing Mac Mini Mid 2011 Speaker: step 10, image 1 of 1
    • Use the tip of a spudger to carefully pry the antenna connector up from its socket on the AirPort/Bluetooth board.
  11. Installing Mac Mini Mid 2011 Speaker: step 11, image 1 of 1
    • Remove the antenna plate from the mini.
  12. Installing Mac Mini Mid 2011 Speaker, Logic Board: step 12, image 1 of 2 Installing Mac Mini Mid 2011 Speaker, Logic Board: step 12, image 2 of 2
    • Use the flat end of a spudger to pry the hard drive connector up from its socket on the logic board.
  13. Installing Mac Mini Mid 2011 Speaker: step 13, image 1 of 1
    • Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
    • Make sure to pry up from beneath the wires and not underneath the socket.
  14. Installing Mac Mini Mid 2011 Speaker: step 14, image 1 of 1
    • Remove the following three screws:
    • One 5.0 mm T8 Torx or 2.0 mm Hex screw (either screwdriver will work)
    • One 16.2 mm T6 Torx screw
    • One 26 mm T6 Torx standoff
  15. Installing Mac Mini Mid 2011 Speaker: step 15, image 1 of 3 Installing Mac Mini Mid 2011 Speaker: step 15, image 2 of 3 Installing Mac Mini Mid 2011 Speaker: step 15, image 3 of 3
    Tool used on this step:
    Mac mini Logic Board Removal Tool
    Buy
    • To remove the logic board, the two cylindrical rods of the Mac mini Logic Board Removal Tool must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the top side of outer case below the logic board before proceeding.
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the I/O board is visibly separated from the outer case.
    • Remove the Mac mini Logic Board Removal tool.
  16. Installing Mac Mini Mid 2011 Speaker: step 16, image 1 of 1
    • Pull the I/O board/logic board assembly out of the outer case enough to access the power connector.
    • Use your fingers to disconnect the DC-In cable from the logic board.
    • Pull the power cable connector toward the front side of the mini.
  17. Installing Mac Mini Mid 2011 Speaker: step 17, image 1 of 1
    • Carefully slide the logic board assembly out of the mini, minding any cables that may get caught.
  18. Installing Mac Mini Mid 2011 Speaker, Speaker: step 18, image 1 of 1
    • Remove the following two screws securing the speaker to the logic board assembly:
    • One 3.5 mm T6 Torx screw
    • One 3.7 mm T6 Torx screw
  19. Installing Mac Mini Mid 2011 Speaker: step 19, image 1 of 2 Installing Mac Mini Mid 2011 Speaker: step 19, image 2 of 2
    • Lift but do not remove the speaker assembly, as it still remains connected to the logic board via the speaker connector.
    • Carefully lift the speaker wires upward to lift the speaker connector up and out of its socket on the logic board.
    • Lift and remove the speaker away from the logic board.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 17
All Time: 6,602
