Mac Mini Mid 2010 Antenna Plate Replacement
  1. Mac Mini Mid 2010 Antenna Plate Replacement, Bottom Cover: step 1, image 1 of 2 Mac Mini Mid 2010 Antenna Plate Replacement, Bottom Cover: step 1, image 2 of 2
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
  2. Mac Mini Mid 2010 Antenna Plate Replacement: step 2, image 1 of 1
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
  3. Mac Mini Mid 2010 Antenna Plate Replacement, Fan: step 3, image 1 of 1
    • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
  4. Mac Mini Mid 2010 Antenna Plate Replacement: step 4, image 1 of 1
    • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
    • If the fan doesn't separate from the standoff screw with a moderate amount of force, you can use a T6 Torx driver to simply remove this screw.
  5. Mac Mini Mid 2010 Antenna Plate Replacement: step 5, image 1 of 1
    • Lift the fan out of the mini for enough clearance to access its connector.
    • Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
    • Remove the fan.
  6. Mac Mini Mid 2010 Antenna Plate Replacement, Cowling: step 6, image 1 of 1
    • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
  7. Mac Mini Mid 2010 Antenna Plate Replacement: step 7, image 1 of 1
    • Lift the cowling from the end nearest the antenna plate.
    • Rotate the cowling away from the outer case and remove it from the mini.
  8. Mac Mini Mid 2010 Antenna Plate Replacement, Antenna Plate: step 8, image 1 of 1
    • Remove the following screws securing the antenna plate to the mini:
    • Two 6.6 mm T8 Torx screws
    • Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either will work)
  9. Mac Mini Mid 2010 Antenna Plate Replacement: step 9, image 1 of 2 Mac Mini Mid 2010 Antenna Plate Replacement: step 9, image 2 of 2
    • Slightly lift the antenna plate from the end closest to the RAM.
    • Carefully pull the antenna plate straight away from the circular rim of the outer case.
    • Do not remove the antenna plate yet. It is still attached to the AirPort/ Bluetooth board.
  10. Mac Mini Mid 2010 Antenna Plate Replacement: step 10, image 1 of 1
    • Use the tip of a spudger to carefully pry the antenna connector up off the AirPort/Bluetooth board.
  11. Mac Mini Mid 2010 Antenna Plate Replacement: step 11, image 1 of 1
    • Remove the antenna plate from the mini.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 26,716
