Disassembling Casio CZ-1000 Backplate
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
64
All Time:
422
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Many Casio CZ-1000 troubleshooting symptoms require opening up the back plate of the digital synthesizer. Inside the keyboard, a number of components are located under the two main motherboards. In this guide, we take you step by step through how to open up the back plate and remove the two main motherboards, giving access to the components below.
Tools
    1. Disassembling Casio CZ-1000 Backplate, Backplate: step 1, image 1 of 2 Disassembling Casio CZ-1000 Backplate, Backplate: step 1, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
      Ask FixBot
    2. Disassembling Casio CZ-1000 Backplate: step 2, image 1 of 3 Disassembling Casio CZ-1000 Backplate: step 2, image 2 of 3 Disassembling Casio CZ-1000 Backplate: step 2, image 3 of 3
      • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
      • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
      Ask FixBot
    3. Disassembling Casio CZ-1000 Backplate: step 3, image 1 of 3 Disassembling Casio CZ-1000 Backplate: step 3, image 2 of 3 Disassembling Casio CZ-1000 Backplate: step 3, image 3 of 3
      • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
      • Be sure to avoid cutting any nearby wires or components.
      • Gently slide all the plugs out of their sockets.
      • This will prevent them from catching on anything or damaging the connectors as you lift.
      Ask FixBot
Jace Alexander
181 Reputation
2 Guides authored
Cuesta, Team 60-3, Krynen Fall 2024 Member of Cuesta, Team 60-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 64
All Time: 422
