Replacing Oakley Flak 2 Lens and Rubber Kits
    1. Replacing Oakley Flak 2 Lens and Rubber Kits, Lens & Rubber Kits: step 1, image 1 of 3 Replacing Oakley Flak 2 Lens and Rubber Kits, Lens & Rubber Kits: step 1, image 2 of 3 Replacing Oakley Flak 2 Lens and Rubber Kits, Lens & Rubber Kits: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Pinch the tweezers and place them against the rubber ear socket.
      • Push the tweezers through the hole.
      • Slowly pull out the rubber ear sock.
      • Repeat the previous steps for the other side.
      Ask FixBot
    2. Replacing Oakley Flak 2 Lens and Rubber Kits: step 2, image 1 of 2 Replacing Oakley Flak 2 Lens and Rubber Kits: step 2, image 2 of 2
      • Pull up on the bottom of the rubber nose pad.
      • Push the rubber nose pad up to remove it.
      • Repeat the steps for the other side.
      Ask FixBot
    3. Replacing Oakley Flak 2 Lens and Rubber Kits: step 3, image 1 of 2 Replacing Oakley Flak 2 Lens and Rubber Kits: step 3, image 2 of 2
      • From the bridge of the glasses, push the bottom outer corner of the lens up.
      • Use the groove to slide the dislodged side of the lens down and out.
      Ask FixBot
    4. Replacing Oakley Flak 2 Lens and Rubber Kits: step 4, image 1 of 3 Replacing Oakley Flak 2 Lens and Rubber Kits: step 4, image 2 of 3 Replacing Oakley Flak 2 Lens and Rubber Kits: step 4, image 3 of 3
      • Make sure to match the correct ear sock to the correct temple side.
      • Insert the glasses temple in the rubber sock
      • Push/ Pull the rubber sock forward.
      • Push in the rubber tab into the hole near the hinge.
      Ask FixBot
    5. Replacing Oakley Flak 2 Lens and Rubber Kits: step 5, image 1 of 3 Replacing Oakley Flak 2 Lens and Rubber Kits: step 5, image 2 of 3 Replacing Oakley Flak 2 Lens and Rubber Kits: step 5, image 3 of 3
      • Insert the rubber nose pad from the top.
      • Stretch the nose pad at the bottom and insert the bottom tab into nose pad.
      Ask FixBot
    6. Replacing Oakley Flak 2 Lens and Rubber Kits: step 6, image 1 of 3 Replacing Oakley Flak 2 Lens and Rubber Kits: step 6, image 2 of 3 Replacing Oakley Flak 2 Lens and Rubber Kits: step 6, image 3 of 3
      • Insert the lens from the outer top corner.
      • Push the bottom corner of the lens closest to the frame's bridge up. An auditable pop will indicate the lens is inserted.
      • Repeat these steps for the other side.
      Ask FixBot
    7. Replacing Oakley Flak 2 Lens and Rubber Kits: step 7, image 1 of 2 Replacing Oakley Flak 2 Lens and Rubber Kits: step 7, image 2 of 2
      Microfiber Cleaning Cloths
      $3.99
      Buy
      Ask FixBot
This guide can allow you to mix and match various rubber kits, and lens to create your own Oakley Flak 2 sunglasses.
2 other people completed this guide.
Peter Tran
193 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 107
All Time: 3,740
