Introduction
Use this guide to replace the PCIe SSD cable in the SSD-only or Fusion drive models of the Mac mini Late 2014.
The bottom cover is clipped onto three screw posts.
Pry near, but not right on the screw posts.
Remove the following TR6 screws from the antenna plate:
Three 4.1 mm screws
Three 1.9 mm screws
Remove the two 2.6 mm T6 screws securing the PCIe SSD cable bracket.
PCIe SSD & flex cable install on Mac Mini (late 2014) for OS X Fusion Drive [Teardown & Reassembly]
Slip the flat end of a spudger under the SSD cable to lift it off the adhesive holding it to the Mac mini.
Was not possible - glue in my Mac Mini was way to strong. I destructively ripped out the cable and used a combined adapter/cable to connect a new SSD.
I had to use the metallic spudger (Jimmy) to separate the SSD cable. It was a bit tricky but started with a corner and once it yielded a bit it was easy from there. It was not easy in such a small area.
Remove the PCIe SSD cable from the Mac mini.
Where do I can buy a PCIe SSD cable?
I can also supply the cable alone (not requiring a full disassembly). Please reply if interested.
I’m interested in the cable.
28 other people completed this guide.
8 Comments
Where i can buy the PCIe SSD card?
Where i can buy the PCIe SSD card, someone?
I can supply these cables. Please reply to this thread.
I found the ssd kit on eBay for $69ish. However, it doesn't include the ssd. Is it mPCI-e or is it an M.2 module?
The SSD is neither, I believe. It is the same as the SSDs in the 2014 and up MacBook Pros. Pin format is 12+16
the flex for Mac mini 2014 is on aliexpress
¿Sabrían si el ssd pcie wd green es compatible? gracias saludos.
Hi at all
I’ve bought :
_cablecc m-Key Nvme SSD M.2 NGFF Scheda convertitore per 2014 MacBook Mini A1347 MEGEN2 MEGEM2 MEGEQ2
_Transcend TS256GMTE110S Unità a Stato Solido Interne PCIe Gen 3x4 MTE110S, M.2 NVMe, 256 GB
I installed all on my mac mini late 2014, the SSD works but is not possible install on that the MAC OS because I can’t create GUID partitioning also over the formatting Journaled .
It’s normal or I’ve to do some preliminary operation?
Thanks
Attilio
