Mac Mini Late 2014 Antenna Plate Replacement
  1. Mac Mini Late 2014 Antenna Plate Replacement, Bottom Cover: step 1, image 1 of 1
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
  2. Mac Mini Late 2014 Antenna Plate Replacement: step 2, image 1 of 3 Mac Mini Late 2014 Antenna Plate Replacement: step 2, image 2 of 3 Mac Mini Late 2014 Antenna Plate Replacement: step 2, image 3 of 3
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
  3. Mac Mini Late 2014 Antenna Plate Replacement: step 3, image 1 of 2 Mac Mini Late 2014 Antenna Plate Replacement: step 3, image 2 of 2
    • Lift and remove the bottom cover.
  4. Mac Mini Late 2014 Antenna Plate Replacement, Antenna Plate: step 4, image 1 of 1
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
  5. Mac Mini Late 2014 Antenna Plate Replacement: step 5, image 1 of 2 Mac Mini Late 2014 Antenna Plate Replacement: step 5, image 2 of 2
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. Mac Mini Late 2014 Antenna Plate Replacement: step 6, image 1 of 1
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
  7. Mac Mini Late 2014 Antenna Plate Replacement: step 7, image 1 of 2 Mac Mini Late 2014 Antenna Plate Replacement: step 7, image 2 of 2
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
  8. Mac Mini Late 2014 Antenna Plate Replacement: step 8, image 1 of 2 Mac Mini Late 2014 Antenna Plate Replacement: step 8, image 2 of 2
    • Carefully pull the antenna cable out from the gap between the power supply and case.
  9. Mac Mini Late 2014 Antenna Plate Replacement: step 9, image 1 of 1
    • Remove the antenna plate from the Mac Mini.
Sam Goldheart
466,153 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,420 Guides authored
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 109
All Time: 13,149
