Mac mini (PowerPC) Hard Drive Replacement
  1. Mac mini (PowerPC) Hard Drive Replacement, Mass Storage Unit: step 1, image 1 of 1
    • If your mini does not have Airport installed, then skip this step.
    • Grasp the Airport antenna board and lift it off of the two plastic posts holding it in place. You may need to push back the black plastic tab jutting through the lower left corner of the board.
  2. Mac mini (PowerPC) Hard Drive Replacement: step 2, image 1 of 1
    • Remove the yellow tape securing the power button cable to the black plastic framework.
  3. Mac mini (PowerPC) Hard Drive Replacement: step 3, image 1 of 1
    • Remove the three black Phillips screws securing the plastic framework to the logic board and lower case.
  4. Mac mini (PowerPC) Hard Drive Replacement: step 4, image 1 of 1
    • Grasp the optical drive and mass storage unit in one hand and lift up enough so that you can see beneath it.
  5. Mac mini (PowerPC) Hard Drive Replacement: step 5, image 1 of 1
    • If your mini has neither an Airport card nor a Bluetooth board, you can simply lift the optical drive up and away. Otherwise, you need to disconnect the Airport and/or Bluetooth antenna cables first.
    • With your free hand, pull the Bluetooth cable up from Bluetooth board and unplug the Airport antenna cable from the right of the Airport card. Caution: both of these connections are very small. When re-assembling unit after repair, you may want to remove the two screws holding the airport card to the assembly and lift the card up and out to re-attach the cables.
  6. Mac mini (PowerPC) Hard Drive Replacement, Hard Drive: step 6, image 1 of 1
    • Remove the three long, black Phillips screws from the corners of the fan. These screws are strongly threaded, and will offer significant resistance.
    • There is no screw in the bottom left corner.
  7. Mac mini (PowerPC) Hard Drive Replacement: step 7, image 1 of 1
    • Lift the fan out of the computer.
  8. Mac mini (PowerPC) Hard Drive Replacement: step 8, image 1 of 1
    • Peel up the yellow tape securing the speaker and fan cables to the bottom of the hard drive.
  9. Mac mini (PowerPC) Hard Drive Replacement: step 9, image 1 of 1
    • Use a #1 Phillips to remove the two screws attaching the right side of the hard drive to the plastic framework. You'll need to angle the screwdriver down to get access to the lower right screw. Be sure to apply steady force to the screws and turn slowly so as not to strip them.
  10. Mac mini (PowerPC) Hard Drive Replacement: step 10, image 1 of 1
    • Use the same screwdriver and steady force to remove the two screws attaching the left side of the hard drive to the plastic framework.
  11. Mac mini (PowerPC) Hard Drive Replacement: step 11, image 1 of 1
    • Use a spudger to pry the hard drive away from the interface board. Wedge the flat end of the spudger between the interface board and the far right side of hard drive and wiggle back and forth until the hard drive slides out about a sixteenth of an inch. Then move to the other side and repeat the procedure. Go back and forth until the hard drive slides free.
    • When reinstalling the hard drive, make sure that you don't slide the top pins into the lower row of holes.
  12. Mac mini (PowerPC) Hard Drive Replacement: step 12, image 1 of 1
    • Lift the hard drive out of the assembly.
Attached Documents
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 6
Past 7 Days: 28
Past 30 Days: 187
All Time: 120,912
