Installing Mac mini (PowerPC) Fan
  1. Installing Mac mini (PowerPC) Fan, Mass Storage Unit: step 1, image 1 of 1
    • If your mini does not have Airport installed, then skip this step.
    • Grasp the Airport antenna board and lift it off of the two plastic posts holding it in place. You may need to push back the black plastic tab jutting through the lower left corner of the board.
  2. Installing Mac mini (PowerPC) Fan: step 2, image 1 of 1
    • Remove the yellow tape securing the power button cable to the black plastic framework.
  3. Installing Mac mini (PowerPC) Fan: step 3, image 1 of 1
    • Remove the three black Phillips screws securing the plastic framework to the logic board and lower case.
  4. Installing Mac mini (PowerPC) Fan: step 4, image 1 of 1
    • Grasp the optical drive and mass storage unit in one hand and lift up enough so that you can see beneath it.
  5. Installing Mac mini (PowerPC) Fan: step 5, image 1 of 1
    • If your mini has neither an Airport card nor a Bluetooth board, you can simply lift the optical drive up and away. Otherwise, you need to disconnect the Airport and/or Bluetooth antenna cables first.
    • With your free hand, pull the Bluetooth cable up from Bluetooth board and unplug the Airport antenna cable from the right of the Airport card. Caution: both of these connections are very small. When re-assembling unit after repair, you may want to remove the two screws holding the airport card to the assembly and lift the card up and out to re-attach the cables.
  6. Installing Mac mini (PowerPC) Fan, Fan: step 6, image 1 of 1
    • Flip the mass storage assembly over so that the fan faces up.
    • Remove the three long, black Phillips screws from the corners of the fan. These screws are strongly threaded, and will offer significant resistance.
    • There is no screw in the bottom left corner.
  7. Installing Mac mini (PowerPC) Fan: step 7, image 1 of 1
    • Lift the fan up and deroute its cable from the plastic framework and the bottom of the hard drive, removing tape as necessary.
  8. Installing Mac mini (PowerPC) Fan: step 8, image 1 of 1
    • The cable you're about to remove is very fragile - do not pull directly on the wires. Instead, try to pry up the connector directly, using your fingernails or a small flathead screwdriver if necessary.
    • Disconnect the fan connector from the interface board.
Attached Documents
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 19
All Time: 12,271
