Mac Pro Late 2013 Graphics Card Replacement
    1. Mac Pro Late 2013 Graphics Card Replacement, Outer Case: step 1, image 1 of 2 Mac Pro Late 2013 Graphics Card Replacement, Outer Case: step 1, image 2 of 2
      • Slide the lock switch to the right, to the unlocked position.
      Ask FixBot
    2. Mac Pro Late 2013 Graphics Card Replacement: step 2, image 1 of 3 Mac Pro Late 2013 Graphics Card Replacement: step 2, image 2 of 3 Mac Pro Late 2013 Graphics Card Replacement: step 2, image 3 of 3
      • Lift the outer case straight up off the Mac Pro.
      • It may help to push down on the center of the fan while lifting the case up.
      Ask FixBot
    1. Mac Pro Late 2013 Graphics Card Replacement, Fan Assembly: step 3, image 1 of 3 Mac Pro Late 2013 Graphics Card Replacement, Fan Assembly: step 3, image 2 of 3 Mac Pro Late 2013 Graphics Card Replacement, Fan Assembly: step 3, image 3 of 3
      • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
      Ask FixBot
    2. Mac Pro Late 2013 Graphics Card Replacement: step 4, image 1 of 2 Mac Pro Late 2013 Graphics Card Replacement: step 4, image 2 of 2
      • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
      • Tilt the assembly up away from the IO board.
      • Do not try to remove the fan assembly yet, as it is still attached by two cables.
      Ask FixBot
    3. Mac Pro Late 2013 Graphics Card Replacement: step 5, image 1 of 1
      • While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
      • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
      Ask FixBot
    4. Mac Pro Late 2013 Graphics Card Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
      Ask FixBot
    5. Mac Pro Late 2013 Graphics Card Replacement: step 7, image 1 of 2 Mac Pro Late 2013 Graphics Card Replacement: step 7, image 2 of 2
      • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
      Ask FixBot
    6. Mac Pro Late 2013 Graphics Card Replacement: step 8, image 1 of 1
      • Disconnect the fan assembly antenna cable from the IO board.
      • Remove the fan assembly from the Mac Pro.
      Ask FixBot
    1. Mac Pro Late 2013 Graphics Card Replacement, Lower Case: step 9, image 1 of 3 Mac Pro Late 2013 Graphics Card Replacement, Lower Case: step 9, image 2 of 3 Mac Pro Late 2013 Graphics Card Replacement, Lower Case: step 9, image 3 of 3
      • Flip the Mac Pro upside down, 180 degrees.
      • Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
      Ask FixBot
    2. Mac Pro Late 2013 Graphics Card Replacement: step 10, image 1 of 2 Mac Pro Late 2013 Graphics Card Replacement: step 10, image 2 of 2
      • Carefully lift the lower case up and remove it from the Mac Pro.
      Ask FixBot
    1. Mac Pro Late 2013 Graphics Card Replacement, Graphics Card: step 11, image 1 of 2 Mac Pro Late 2013 Graphics Card Replacement, Graphics Card: step 11, image 2 of 2
      • Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
      Ask FixBot
    2. Mac Pro Late 2013 Graphics Card Replacement: step 12, image 1 of 3 Mac Pro Late 2013 Graphics Card Replacement: step 12, image 2 of 3 Mac Pro Late 2013 Graphics Card Replacement: step 12, image 3 of 3
      • Gently separate the other side as well.
      • Flip the connector up and out of the way of the graphics card.
      Ask FixBot
    3. Mac Pro Late 2013 Graphics Card Replacement: step 13, image 1 of 1
      • Remove the two 6.6 mm T8 Torx Security screws securing the GPU to the Mac Pro.
      • These screws fit into power cables behind the GPU. Be careful not to over-tighten and twist the cables.
      Ask FixBot
    4. Mac Pro Late 2013 Graphics Card Replacement: step 14, image 1 of 1
      • Remove the four 8.4 mm T10 screws from the GPU heat sink bracket.
      Ask FixBot
    5. Mac Pro Late 2013 Graphics Card Replacement: step 15, image 1 of 1
      • Remove the GPU heat sink bracket.
      Ask FixBot
    6. Mac Pro Late 2013 Graphics Card Replacement: step 16, image 1 of 3 Mac Pro Late 2013 Graphics Card Replacement: step 16, image 2 of 3 Mac Pro Late 2013 Graphics Card Replacement: step 16, image 3 of 3
      • The graphics card is now held onto the central heat sink by thermal compound.
      • You may need to pry very gently with a spudger to separate the card from the heat sink.
      • Remove the graphics card from the heat sink.
      Ask FixBot
    7. Mac Pro Late 2013 Graphics Card Replacement: step 17, image 1 of 1
      • During reassembly, be sure to clean off and replace the thermal compound. Use our Applying Thermal Paste guide if you require assistance.
      • Repeat this procedure if you wish to remove the secondary graphics card.
      Ask FixBot
50 other people completed this guide.
Andrew Optimus Goldheart
515,526 Reputation
406 Guides authored
iFixit Member of iFixit
Staff
123 Members
78,635 Guides authored
20 Guide Comments
hey! is it possible to upgrade the GPU or is this just for replacing exactly the same part?
Ben - Reply Share
I am guessing you can upgrade them with OEM parts, but where would we find them?
Fernando Bernardino - Reply Share
Yes. I recently swapped out D300 pairs for D700 pairs without a blip. I did an NVRAM reset afterwards just to be safe.
Technology Research - Reply Share
I have the D300s, and would like to upgrade to the D500s or D700s. Where might I find the replacement graphics cards? Also, any recommendations on service providers who would do this procedure?
Chris M Balz - Reply Share
I'd love to know this as well. The only reason I picked up the ,ad pro was the potential for upgrades. As it turns out D300s are crap. I can't even run boot camp properly.
jerimiahy - Reply Share
Past 24 Hours: 5
Past 7 Days: 79
Past 30 Days: 352
All Time: 117,075
