Introduction
Use this guide to replace the AirPort antenna array in your Mac Pro.
Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
Disconnect the fan assembly antenna cable from the IO board.
Remove the fan assembly from the Mac Pro.
Use the flat end of a spudger to pry the fan assembly lid up off the fan assembly.
Remove the fan assembly lid.
Remove the three 3.7 mm T4 screws securing the metal cover to the AirPort board bay.
Use the tip of a spudger to flip the ZIF retaining tab on the fan assembly ribbon cable connector.
Remove the fan assembly ribbon cable from its ZIF socket.
Use the tip of a spudger to flip the ZIF retaining tab on the fan ribbon cable.
Disconnect the fan ribbon cable.
Remove the three 3.7 mm T4 screws securing the antenna array to the fan assembly.
