Mac Pro Late 2013 AirPort Antenna Array Replacement
  1. Mac Pro Late 2013 AirPort Antenna Array Replacement, Outer Case: step 1, image 1 of 2 Mac Pro Late 2013 AirPort Antenna Array Replacement, Outer Case: step 1, image 2 of 2
    • Slide the lock switch to the right, to the unlocked position.
  2. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 2, image 1 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement: step 2, image 2 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement: step 2, image 3 of 3
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly: step 3, image 1 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly: step 3, image 2 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly: step 3, image 3 of 3
    • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
  4. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 4, image 1 of 2 Mac Pro Late 2013 AirPort Antenna Array Replacement: step 4, image 2 of 2
    • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
    • Tilt the assembly up away from the IO board.
    • Do not try to remove the fan assembly yet, as it is still attached by two cables.
  5. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 5, image 1 of 1
    • While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
    • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
  6. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
  7. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 7, image 1 of 2 Mac Pro Late 2013 AirPort Antenna Array Replacement: step 7, image 2 of 2
    • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
  8. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 8, image 1 of 1
    • Disconnect the fan assembly antenna cable from the IO board.
    • Remove the fan assembly from the Mac Pro.
  9. Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly Lid: step 9, image 1 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly Lid: step 9, image 2 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly Lid: step 9, image 3 of 3
    • Use the flat end of a spudger to pry the fan assembly lid up off the fan assembly.
    • Remove the fan assembly lid.
  10. Mac Pro Late 2013 AirPort Antenna Array Replacement, AirPort Board: step 10, image 1 of 1
    • Remove the three 3.7 mm T4 screws securing the metal cover to the AirPort board bay.
  11. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 11, image 1 of 1
    • Lift and remove the metal cover from the AirPort board bay.
  12. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 12, image 1 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement: step 12, image 2 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement: step 12, image 3 of 3
    • Use the tip of a spudger to flip the ZIF retaining tab on the fan assembly ribbon cable connector.
    • Remove the fan assembly ribbon cable from its ZIF socket.
  13. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 13, image 1 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement: step 13, image 2 of 3 Mac Pro Late 2013 AirPort Antenna Array Replacement: step 13, image 3 of 3
    • Use the tip of a spudger to flip the ZIF retaining tab on the fan ribbon cable.
    • Disconnect the fan ribbon cable.
  14. Mac Pro Late 2013 AirPort Antenna Array Replacement, AirPort Antenna Array: step 14, image 1 of 1
    • Remove three 3.7 mm T4 screws from the antenna array.
  15. Mac Pro Late 2013 AirPort Antenna Array Replacement: step 15, image 1 of 1
    • Remove the AirPort antenna array.
Andrew Optimus Goldheart
503,548 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,523 Guides authored
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 26
All Time: 5,329
