Mac Pro 2009-2012 Case Replacement
  1. Mac Pro 2009-2012 Case Replacement, Open the Case: step 1, image 1 of 3 Mac Pro 2009-2012 Case Replacement, Open the Case: step 1, image 2 of 3 Mac Pro 2009-2012 Case Replacement, Open the Case: step 1, image 3 of 3
    • To open the Mac Pro, you'll have to lift the clip on the back of the case
    • Leave the clip open during the entire disassembly!
  2. Mac Pro 2009-2012 Case Replacement, Remove the side panel: step 2, image 1 of 2 Mac Pro 2009-2012 Case Replacement, Remove the side panel: step 2, image 2 of 2
    • Lift the flap to put it in the unlocked position, the panel should separate from the box without forcing.
  3. Mac Pro 2009-2012 Case Replacement, Remove the hard drives: step 3, image 1 of 2 Mac Pro 2009-2012 Case Replacement, Remove the hard drives: step 3, image 2 of 2
    • Then to remove the hard drives, pull them towards you with a bit of force.
  4. Mac Pro 2009-2012 Case Replacement, Remove the DVD drives: step 4, image 1 of 3 Mac Pro 2009-2012 Case Replacement, Remove the DVD drives: step 4, image 2 of 3 Mac Pro 2009-2012 Case Replacement, Remove the DVD drives: step 4, image 3 of 3
    • Pull the DVD drives towards you, just like the hard drives.
  5. Mac Pro 2009-2012 Case Replacement, Remove the CPU board: step 5, image 1 of 3 Mac Pro 2009-2012 Case Replacement, Remove the CPU board: step 5, image 2 of 3 Mac Pro 2009-2012 Case Replacement, Remove the CPU board: step 5, image 3 of 3
    • Press both latches to unlock the bracket and then pull it towards you.
    • You shouldn't need to apply much force.
  6. Mac Pro 2009-2012 Case Replacement, Disconnect the GPU: step 6, image 1 of 2 Mac Pro 2009-2012 Case Replacement, Disconnect the GPU: step 6, image 2 of 2
    • Remove the 6 or 8 pin connector from your graphics card.
    • This step is optional, it will depend on the graphics card of your Mac Pro
  7. Mac Pro 2009-2012 Case Replacement, Disconnect the GPU power supply ( Optional ): step 7, image 1 of 3 Mac Pro 2009-2012 Case Replacement, Disconnect the GPU power supply ( Optional ): step 7, image 2 of 3 Mac Pro 2009-2012 Case Replacement, Disconnect the GPU power supply ( Optional ): step 7, image 3 of 3
    • On the power supply there is a button, press it to move the power supply to the left (see picture)
    • Then pull the graphics card towards you to take it out of the box
    • This step is optional depending on the GPU of your Mac Pro
  8. Mac Pro 2009-2012 Case Replacement, Disconnect GPU support ( optional): step 8, image 1 of 2 Mac Pro 2009-2012 Case Replacement, Disconnect GPU support ( optional): step 8, image 2 of 2
    • Disconnect the PCI-e cables from the motherboard
    • This step is optional depending on your Mac Pro
  9. Mac Pro 2009-2012 Case Replacement, Take out the PCI-e fan: step 9, image 1 of 3 Mac Pro 2009-2012 Case Replacement, Take out the PCI-e fan: step 9, image 2 of 3 Mac Pro 2009-2012 Case Replacement, Take out the PCI-e fan: step 9, image 3 of 3
    • With a screwdriver unscrew the two screws that hold the fan bracket to the board
    • Pull the fan towards you
  10. Mac Pro 2009-2012 Case Replacement, Disconnect the SATA Cables: step 10, image 1 of 2 Mac Pro 2009-2012 Case Replacement, Disconnect the SATA Cables: step 10, image 2 of 2
    • Behind the fan bracket there are 2 SATA cables, a 4 pin mini power supply and a 4 pin fan
  11. Mac Pro 2009-2012 Case Replacement, Unscrew CPU support: step 11, image 1 of 3 Mac Pro 2009-2012 Case Replacement, Unscrew CPU support: step 11, image 2 of 3 Mac Pro 2009-2012 Case Replacement, Unscrew CPU support: step 11, image 3 of 3
    • With a H2.5 screwdriver, unscrew the screws on the bottom of the bracket (photo 2)
    • With a Phillips screwdriver, unscrew the screws on the bottom of the case (photo 3)
  12. Mac Pro 2009-2012 Case Replacement, Remove the CPU Fan: step 12, image 1 of 3 Mac Pro 2009-2012 Case Replacement, Remove the CPU Fan: step 12, image 2 of 3 Mac Pro 2009-2012 Case Replacement, Remove the CPU Fan: step 12, image 3 of 3
    • Remove the clip at the top of the fan
    • Pull on the top of the fan a bit.
  13. Mac Pro 2009-2012 Case Replacement, Remove the CPU Fan: step 13, image 1 of 2 Mac Pro 2009-2012 Case Replacement, Remove the CPU Fan: step 13, image 2 of 2
    • Similar to the top remove the clip at the bottom and pull out the fan.
  14. Mac Pro 2009-2012 Case Replacement, Disconnect Fan and Speakers: step 14, image 1 of 3 Mac Pro 2009-2012 Case Replacement, Disconnect Fan and Speakers: step 14, image 2 of 3 Mac Pro 2009-2012 Case Replacement, Disconnect Fan and Speakers: step 14, image 3 of 3
    • Disconnect the 2 x 4pin fan cables and the 1 x 2 pin speaker cable
    • Do not forget this step or you risk damaging your connectors on the motherboard and make unusable fans and speaker!
  15. Mac Pro 2009-2012 Case Replacement, Remove the CPU Support: step 15, image 1 of 3 Mac Pro 2009-2012 Case Replacement, Remove the CPU Support: step 15, image 2 of 3 Mac Pro 2009-2012 Case Replacement, Remove the CPU Support: step 15, image 3 of 3
    • Pull the CPU support towards you
    • Do not use force during this step,It it does not come out easily ensure the fans are not blocking the exit.
  16. Mac Pro 2009-2012 Case Replacement, Remove the expansion card connector: step 16, image 1 of 3 Mac Pro 2009-2012 Case Replacement, Remove the expansion card connector: step 16, image 2 of 3 Mac Pro 2009-2012 Case Replacement, Remove the expansion card connector: step 16, image 3 of 3
    • Remove the ribbon that connects the motherboard to the expansion card (USB, Jack, Power Off etc.)
    • Attention, it is necessary to remove the cable carefully so as not to bend the pins which are in the connector of the motherboard!
  17. Mac Pro 2009-2012 Case Replacement, Remove the expansion card: step 17, image 1 of 3 Mac Pro 2009-2012 Case Replacement, Remove the expansion card: step 17, image 2 of 3 Mac Pro 2009-2012 Case Replacement, Remove the expansion card: step 17, image 3 of 3
    • Unscrew the 6 screws that hold the card in place.
    • Be careful to unplug the power cable on the card !!
  18. Mac Pro 2009-2012 Case Replacement, Remove the cover: step 18, image 1 of 3 Mac Pro 2009-2012 Case Replacement, Remove the cover: step 18, image 2 of 3 Mac Pro 2009-2012 Case Replacement, Remove the cover: step 18, image 3 of 3
    • unscrew the two screws and remove the cover
  19. Mac Pro 2009-2012 Case Replacement, Unplug the power supply: step 19, image 1 of 3 Mac Pro 2009-2012 Case Replacement, Unplug the power supply: step 19, image 2 of 3 Mac Pro 2009-2012 Case Replacement, Unplug the power supply: step 19, image 3 of 3
    • Push on both knobs to remove the power connector
    • Do not use force, if you are struggling ensure you are squeezing the clips adequately.
  20. Mac Pro 2009-2012 Case Replacement, Separate the power supply: step 20, image 1 of 2 Mac Pro 2009-2012 Case Replacement, Separate the power supply: step 20, image 2 of 2
    • Unscrew the 4 screws that hold in the power supply
  21. Mac Pro 2009-2012 Case Replacement, Remove the power supply: step 21, image 1 of 3 Mac Pro 2009-2012 Case Replacement, Remove the power supply: step 21, image 2 of 3 Mac Pro 2009-2012 Case Replacement, Remove the power supply: step 21, image 3 of 3
    • Pull the power supply towards you.
    • Be sure to pull the connector forward and watch the cables
  22. Mac Pro 2009-2012 Case Replacement, Detach the bluetooth antenna: step 22, image 1 of 3 Mac Pro 2009-2012 Case Replacement, Detach the bluetooth antenna: step 22, image 2 of 3 Mac Pro 2009-2012 Case Replacement, Detach the bluetooth antenna: step 22, image 3 of 3
    • Unclip the bluetooth antenna
  23. Mac Pro 2009-2012 Case Replacement, Remove the mother board: step 23, image 1 of 3 Mac Pro 2009-2012 Case Replacement, Remove the mother board: step 23, image 2 of 3 Mac Pro 2009-2012 Case Replacement, Remove the mother board: step 23, image 3 of 3
    • Unscrew the 10 screws holding in the motherboard
  24. Mac Pro 2009-2012 Case Replacement, Change the case: step 24, image 1 of 1
    • Follow the steps in reverse to resemble.
To resemble, follow the instructions in the reverse order.
21 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
remitouch
979 Reputation
1 Guide authored
7 Comments
Bonjour, j’ai un mac pro 5,1 de 2010 dont les clapets (ou les trappes, j’ignore le terme exact) de la baie des lecteurs de disques restent ouverts à chaque fois qu’ils sont actionnés. Je n’ai pas réussi à les démonter, et les 2 gouttes de 3 en 1 sur les glissières latérales n’ont rien changé au problème. Je n’ai trouvé aucun tutoriel, ni même aucune occurrence de ce problème sur le web. Pourriez-vous me donner quelques conseils ? Merci.
Gabriel Fracque - Reply
Amazing explanations and perfect picture track on each move made.
Thanks much - this was very helpful :)
Dennis.
Dennis OBrien - Reply
Hello sir , I have a problem with my Mac Pro 5,1 mid 2010 Xeon 6core Cpu 64 GB Ram RX580
I erase SSD Hard Drive and I want to reinstall mojave OS and it does not work still appear ‘Missing Operating System’
I try to use all commends on startup like (Option) (Commend+R) (Option+Commend+R)(Option+Commend+R+P) and more commends
but nothing work with it … please I want help . I need your help please , please …
Hussain Khan - Reply
You’d probably get an answer a lot quicker if you just posted that as a question.
[deleted] -
Thanks for posting this guide!
I used it to replace all the cooking fans in my macpro5,1. Worked great!!
Andrew Clark - Reply
Past 24 Hours: 8
Past 7 Days: 75
Past 30 Days: 300
All Time: 24,489
