Mac Mini Mid 2010 Fan Replacement
  1. Mac Mini Mid 2010 Fan Replacement, Bottom Cover: step 1, image 1 of 2 Mac Mini Mid 2010 Fan Replacement, Bottom Cover: step 1, image 2 of 2
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
  2. Mac Mini Mid 2010 Fan Replacement: step 2, image 1 of 1
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
  3. Mac Mini Mid 2010 Fan Replacement, Fan: step 3, image 1 of 1
    • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
  4. Mac Mini Mid 2010 Fan Replacement: step 4, image 1 of 1
    • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
  5. Mac Mini Mid 2010 Fan Replacement: step 5, image 1 of 1
    • Lift the fan out of the mini for enough clearance to access its connector.
    • Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
    • Remove the fan.
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 46
All Time: 16,006
