Shop the Holiday Gift Guide
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
MSI Pulse GL76 RAM Replacement
View statistics:
Past 24 Hours:
11
Past 7 Days:
23
Past 30 Days:
42
All Time:
31
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
RAM replacement / addition
Guide created using the disassembly video from LaptopMedia: MSI Pulse GL76 and M.F. LAB MSI Pulse(GL76)/ Katana(GF76)/ Sword/ Crosshair/ Alpha 17/ WF76 Series SSD & RAM Upgrade Tutorial
Warning: The LaptopMedia video also exists for the GL76 12Ux
Guide written following the actual disassembly of my own device
Tools
    1. MSI Pulse GL76 RAM Replacement, Lower Case: step 1, image 1 of 1
      • Remove the 13 Phillips screws that secure the lower case in place (12 M2.5 x 12 mm screws and 1 shorter M2 x 4 mm screw) as indicated in the photo
      • Tool: Phillips screwdriver PH1
      Ask FixBot
    2. MSI Pulse GL76 RAM Replacement: step 2, image 1 of 3 MSI Pulse GL76 RAM Replacement: step 2, image 2 of 3 MSI Pulse GL76 RAM Replacement: step 2, image 3 of 3
      • Insert an opening pick or a thin plastic card into the seam along the frame, then gently slide it around to unclip the lower case from the rest of the laptop.
      • Tool: opening pick
      Ask FixBot
    3. MSI Pulse GL76 RAM Replacement: step 3, image 1 of 1
      • Once all the snap fits on the sides and front are undone, gently lift the cover.
      • Tilt it slightly toward the back to release the final snap fits located near the clutch hinge, then remove it completely.
      Ask FixBot
    1. MSI Pulse GL76 RAM Replacement, RAM: step 4, image 1 of 3 MSI Pulse GL76 RAM Replacement, RAM: step 4, image 2 of 3 MSI Pulse GL76 RAM Replacement, RAM: step 4, image 3 of 3
      • Removal of the cover: Gently lift the black plastic protective sheet (the thermal/insulating cover) that covers the RAM slots to access the RAM sticks.
      • Unclipping the RAM stick: Simultaneously and gently push the two small metal tabs located on each side of the SODIMM port in the direction of the blue arrows (outward).
      • Extraction: The RAM stick will automatically pop up due to the spring. Simply remove it by gently pulling it backward along the axis of its connector.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Author
with
cobra74
350 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 23
Past 30 Days: 42
All Time: 31
