MSI GP62MVR 6RF Leopard Pro Battery Replacement
  1. MSI GP62MVR 6RF Leopard Pro Battery Replacement, Bottom Cover: step 1, image 1 of 2 MSI GP62MVR 6RF Leopard Pro Battery Replacement, Bottom Cover: step 1, image 2 of 2
    • Place the laptop upside down.
    • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
  2. MSI GP62MVR 6RF Leopard Pro Battery Replacement: step 2, image 1 of 2 MSI GP62MVR 6RF Leopard Pro Battery Replacement: step 2, image 2 of 2
    • Use the Jimmy tool to evenly pry loose the bottom cover.
    • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
  3. MSI GP62MVR 6RF Leopard Pro Battery Replacement: step 3, image 1 of 1
    • Remove the back cover.
    • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
  4. MSI GP62MVR 6RF Leopard Pro Battery Replacement, Battery: step 4, image 1 of 1
    • Remove one 5.5 mm screw with a Phillips #0 screwdriver.
  5. MSI GP62MVR 6RF Leopard Pro Battery Replacement: step 5, image 1 of 2 MSI GP62MVR 6RF Leopard Pro Battery Replacement: step 5, image 2 of 2
    • Remove the battery by pulling it outwards, away from the center.
    • There are pins on the bottom left edge that need to be carefully removed.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 19
All Time: 1,210
