MSI GE72 6QF Apache Pro SSD Replacement
  1. MSI GE72 6QF Apache Pro SSD Replacement, Battery: step 1, image 1 of 2 MSI GE72 6QF Apache Pro SSD Replacement, Battery: step 1, image 2 of 2
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro SSD Replacement: step 2, image 1 of 1
    • Slide the optical drive out of the laptop.
  3. MSI GE72 6QF Apache Pro SSD Replacement: step 3, image 1 of 1
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro SSD Replacement: step 4, image 1 of 2 MSI GE72 6QF Apache Pro SSD Replacement: step 4, image 2 of 2
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro SSD Replacement: step 5, image 1 of 2 MSI GE72 6QF Apache Pro SSD Replacement: step 5, image 2 of 2
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro SSD Replacement: step 6, image 1 of 2 MSI GE72 6QF Apache Pro SSD Replacement: step 6, image 2 of 2
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro SSD Replacement, SSD: step 7, image 1 of 2 MSI GE72 6QF Apache Pro SSD Replacement, SSD: step 7, image 2 of 2
    • Locate the SSD and remove the single 5.5mm Phillips #1 screw.
  8. MSI GE72 6QF Apache Pro SSD Replacement: step 8, image 1 of 2 MSI GE72 6QF Apache Pro SSD Replacement: step 8, image 2 of 2
    • Pull out the SSD by gently wiggling it from side to side until it comes out.
    • If the old SSD you removed contains the operating system, then the new SSD must also contain an operating system.
Tanmay Kumar
458 Reputation
4 Guides authored
Cal Poly, Team S14-G4, Banghart Spring 2017 Member of Cal Poly, Team S14-G4, Banghart Spring 2017
CPSU-BANGHART-S17S14G4
4 Members
8 Guides authored
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 61
All Time: 7,690
