MSI GE62 Apache Pro 004 Motherboard Replacement
  1. MSI GE62 Apache Pro 004 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Motherboard Replacement: step 2, image 1 of 2 MSI GE62 Apache Pro 004 Motherboard Replacement: step 2, image 2 of 2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate by pulling away from laptop
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Motherboard Replacement: step 3, image 1 of 3 MSI GE62 Apache Pro 004 Motherboard Replacement: step 3, image 2 of 3 MSI GE62 Apache Pro 004 Motherboard Replacement: step 3, image 3 of 3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Motherboard Replacement, Motherboard: step 4, image 1 of 2 MSI GE62 Apache Pro 004 Motherboard Replacement, Motherboard: step 4, image 2 of 2
    • Remove the cooling assembly by unscrewing the fourteen screws holding it in place.
  5. MSI GE62 Apache Pro 004 Motherboard Replacement: step 5, image 1 of 3 MSI GE62 Apache Pro 004 Motherboard Replacement: step 5, image 2 of 3 MSI GE62 Apache Pro 004 Motherboard Replacement: step 5, image 3 of 3
    • Remove the speakers holding the motherboard in place, located on the bottom left and bottom right of the device.
    • Unfasten the 8 screws holding the motherboard in place.
    • Pull out the motherboard.
Alexander
86 Reputation
1 Guide authored
USF Tampa, Team S15-G5, Boczar Spring 2018 Member of USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 Members
5 Guides authored
1 Guide Comment
Hi,can i change msi ge62 6qf motherboard with ge62 7rd apache pro?
Its essential for me.tnx.
rahim dargahi - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 2,307
