MSI GE62 6QF Apache Pro Hard Drive Replacement
  1. MSI GE62 6QF Apache Pro Hard Drive Replacement, Optical Drive: step 1, image 1 of 1
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
  2. MSI GE62 6QF Apache Pro Hard Drive Replacement: step 2, image 1 of 1
    • Slide Optical Drive out of the computer.
  3. MSI GE62 6QF Apache Pro Hard Drive Replacement, Bottom Case: step 3, image 1 of 1
    • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
    • One of these screws is hidden under a sticker.
  4. MSI GE62 6QF Apache Pro Hard Drive Replacement: step 4, image 1 of 3 MSI GE62 6QF Apache Pro Hard Drive Replacement: step 4, image 2 of 3 MSI GE62 6QF Apache Pro Hard Drive Replacement: step 4, image 3 of 3
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
  5. MSI GE62 6QF Apache Pro Hard Drive Replacement: step 5, image 1 of 2 MSI GE62 6QF Apache Pro Hard Drive Replacement: step 5, image 2 of 2
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
  6. MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: step 6, image 1 of 3 MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: step 6, image 2 of 3 MSI GE62 6QF Apache Pro Hard Drive Replacement, Battery: step 6, image 3 of 3
    • Remove the single PH #0 5mm screw holding the battery pack in place.
    • Remove the battery by sliding it away from the computer.
  7. MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: step 7, image 1 of 3 MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: step 7, image 2 of 3 MSI GE62 6QF Apache Pro Hard Drive Replacement, Hard Drive: step 7, image 3 of 3
    • Unscrew the two black PH #0 2mm screws holding the lower part the hard drive plate
    • Unscrew the two PH #0 4mm screws holding the upper part of the hard drive plate
  8. MSI GE62 6QF Apache Pro Hard Drive Replacement: step 8, image 1 of 2 MSI GE62 6QF Apache Pro Hard Drive Replacement: step 8, image 2 of 2
    • Remove the hard drive by gently lifting up and pulling the drive out of the connection slot
5 other people completed this guide.
Justice Owens
589 Reputation
4 Guides authored
USF Tampa, Team S2-G3, Passmore Fall 2017 Member of USF Tampa, Team S2-G3, Passmore Fall 2017
USFT-PASSMORE-F17S2G3
3 Members
5 Guides authored
4 Comments
Saved my life, would have had no idea what to do without these instructions and would probably have broke something. My new 2tb ssd is working fine
Simon Porter - Reply
Upgraded the Memory to 32GB and the HDD to a 1TB SATA SSD.
Prabodha Elangasinha - Reply
Only issue I ran into was one of the optical drive screws was frozen in, stripped hard, and I had to fall back on Moodys to break it loose. Once done, everything else was cake.
Chuck Brewer - Reply
My ssd is working fine and the hdd has gone bad on mine... have not even opened mine yet but looking at the pics I wonder where the second drive is located?
Eric Jimenez - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 60
All Time: 7,873
