MSI GE62 6QF Apache Pro Bottom Case Replacement
  1. MSI GE62 6QF Apache Pro Bottom Case Replacement, Optical Drive: step 1, image 1 of 1
    • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
  2. MSI GE62 6QF Apache Pro Bottom Case Replacement: step 2, image 1 of 1
    • Slide Optical Drive out of the computer.
  3. MSI GE62 6QF Apache Pro Bottom Case Replacement, Bottom Case: step 3, image 1 of 1
    • Remove the rest of the PH#0 5mm screws on the back of the laptop.
    • Removing the screw under the warranty sticker will void any warranty on the device. Be sure to send your laptop in to the appropriate service provider to keep your warranty.
  4. MSI GE62 6QF Apache Pro Bottom Case Replacement: step 4, image 1 of 3 MSI GE62 6QF Apache Pro Bottom Case Replacement: step 4, image 2 of 3 MSI GE62 6QF Apache Pro Bottom Case Replacement: step 4, image 3 of 3
    • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
  5. MSI GE62 6QF Apache Pro Bottom Case Replacement: step 5, image 1 of 2 MSI GE62 6QF Apache Pro Bottom Case Replacement: step 5, image 2 of 2
    • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
    • Pry the bottom case and remove from the upper part.
Justice Owens
604 Reputation
4 Guides authored
USF Tampa, Team S2-G3, Passmore Fall 2017 Member of USF Tampa, Team S2-G3, Passmore Fall 2017
USFT-PASSMORE-F17S2G3
3 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 30
All Time: 4,764
