Community-Contributed Guide
Introduction
Go to step 1 ↓Touch Screen POS machine from ORACLE / MICROS.
By default, these 310 models use soldered eMMC storage (ours were only 50gb). this is the process i used to add an ssd
Parts
Tools
flip the device over and remove the power adapter hidden in the stand by unscrewing the thumbscrew, then remove the base by unscrewing the single hex screw
remove the covers for on the left side gently and disconnect the cables from the motherboard
unscrew the back cover. there are 8 captured hex head screws, and two loose Phillips screws. the Philips are under where the coveres were that you removed
flip the back cover over to the left and disconnect the cable from the motherboard
At this point you can insert your sata m.2 drive into the connector and screw it down, if your drive is a 2230. we only had 2280's in stock, to i had to desolder the screw terminal and move it to the 2280 position. note that we found not every ssd worked for this machine. we had good luck with Samsung 860 Pros
