This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
MF 2700H Training Guide
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
30
All Time:
929
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Community-Contributed Guide
    1. MF 2700H Training Guide, Getting to know the Lacito MF 2700H Strapping Machine: step 1, image 1 of 1
      • The MF 2700H strapping machine is one of the most complete semi-automatic strapping machines on the market.
      • Safety, high production, practicality, easy adjustment, and an innovative design—these are some of the highlights of the Lacito MF 2700H.
      • I'll tell you a secret: the MF 2700H is the only one on the market where the operator can store 3 coils, totaling 3,000 m; with this, the machine can seal more than 42,800 packages—the competition can't keep up.
      • So, come with me to learn more about the machine.
      Ask FixBot
    2. MF 2700H Training Guide, Power: step 2, image 1 of 1
      • The first step is to connect the power cable to the machine and to a 220-volt outlet.
      • Lacito Tip: When choosing a place to put the machine, choose a safe, firm spot with enough space, which prevents risks to the integrity of the machine and its users—just don't get hurt while doing it (=.
      Ask FixBot
    3. MF 2700H Training Guide, WINDER: step 3, image 1 of 2 MF 2700H Training Guide, WINDER: step 3, image 2 of 2
      • Now, let's observe the position of the Winder.
      • The Winder is a part located at the front of the machine, responsible for winding the strap. (Photo 1)
      • The position of the Winder must always be the same; it must be at 90 degrees, with one tab facing up and the other tab facing down. (Photo 2)
      • If the Winder is in a position different from the one shown in Photo 2, follow the next step.
      Ask FixBot
    4. MF 2700H Training Guide, WINDER: step 4, image 1 of 3 MF 2700H Training Guide, WINDER: step 4, image 2 of 3 MF 2700H Training Guide, WINDER: step 4, image 3 of 3
      • If the Winder is in the wrong position as shown in Photo 1, follow this step
      • THIS ENTIRE OPERATION MUST BE PERFORMED WITH THE MACHINE TURNED OFF
      • And with the machine turned off, we can access the Winder through a gap located below the part. Then, using your index finger, access this gap and rotate the Winder to the correct position, (Photo 2)
      • The Winder must be in the same position as in Photo 3, with one flap facing up and the other facing down.
      Ask FixBot
    5. MF 2700H Training Guide, Button Functions: step 5, image 1 of 3 MF 2700H Training Guide, Button Functions: step 5, image 2 of 3 MF 2700H Training Guide, Button Functions: step 5, image 3 of 3
      • Now let's look at the functions of the remote control buttons:
      • Main switch, intended to energize and de-energize the machine for maintenance processes.
      • Power button, intended to turn the machine on or off.
      • Emergency button, intended to shut down the machine in case of emergency.
      • Lacito Tip: The machine meets all safety requirements against electric shock, there is no need to be afraid.
      Ask FixBot
    6. MF 2700H Training Guide, Turning on the Machine: step 6, image 1 of 3 MF 2700H Training Guide, Turning on the Machine: step 6, image 2 of 3 MF 2700H Training Guide, Turning on the Machine: step 6, image 3 of 3
      • Now that we know the functions of the buttons, we can turn on the machine.
      • To turn on the machine, activate the master switch, leaving the selector positioned at the yellow indicator (Photo 1).
      • Then press the (I) button to turn on the machine (Green) (Photo 2).
      • After 2 seconds, the control panel screen will light up (Photo 3).
      • Emergency button next step (Step 5)
      • Lacito Tip: If the machine does not turn on, check if the emergency button is engaged; if it is, the operator will have to disengage it by turning the button clockwise.
      Ask FixBot
    7. MF 2700H Training Guide, Emergency button.: step 7, image 1 of 1
      • In case of need for an emergency stop, press the emergency button, it will remain locked in the activated position, immediately cutting off electrical power to the machine and stopping operation, releasing the positioner traction.
      • To deactivate the emergency button, turn it clockwise as indicated on the button.
      • Test the functioning of the emergency button whenever starting a work shift.
      • Never use the emergency button to turn the machine off (only in cases of emergency).
      • It is forbidden to remove any safety item from your machine under penalty of loss of warranty and machine operation.
      Ask FixBot
    8. MF 2700H Training Guide, Let's get to know the control panel now, "Let's go.": step 8, image 1 of 1
      • Now, we can start discovering the control panel functions. I don't know about you, but I couldn't wait.
      • The ESC key is of great importance to us; it is used to go back to the previous screen.
      • The SET key is only used on the second screen, and by pressing it, the operator can change data such as the number of turns and the strap size.
      • The ENT key validates all the data that the operator changes.
      • The numeric keypad from 0 to 9 is of utmost importance; it is used to enter data on screen 2 and to select functions on the other screens.
      • Lacito Tip: The control panel is responsible for communication between the operator and the machine.
      Ask FixBot
    9. MF 2700H Training Guide, Understanding the functions of the 2nd Screen (automatic mode): step 9, image 1 of 2 MF 2700H Training Guide, Understanding the functions of the 2nd Screen (automatic mode): step 9, image 2 of 2
      • Now that we are familiar with the numeric keypad functions, let's start exploring the control panel functions, my favorite part.
      • When you are on the home screen, press the 2 key to access the 2nd screen (automatic mode). (Photo 1)(Photo 2)
      • On this screen (Photo 2), we have some information and data; we can configure the machine here, which allows the operator to select the best strap option for their packaging.
      • The counter is the number of times the machine has been activated, meaning that every time the machine seals a package, it adds 1 to the count.
      • The number of turns is the number of rotations for tightening the strap on the package. I recommend 4 turns, but it depends on your packaging (test other setups).
      • The strap size is the final measurement the strap will have after the package is sealed on the MF 2700H. I recommend 70 mm (test other measurements).
      • Warning: If the operator presses the CLR key, the activation count will reset. This is not very good for the machine because if the count is reset, preventive maintenance will be affected, but if someone accidentally presses it, it's no problem; it happens, just don't keep pressing it all the time!
      • Lacito Tip: The machine only starts operating after entering the second screen, without the need to change any data.
      Ask FixBot
    10. MF 2700H Training Guide, Getting to know the functions of the 3rd Screen (manual mode): step 10, image 1 of 3 MF 2700H Training Guide, Getting to know the functions of the 3rd Screen (manual mode): step 10, image 2 of 3 MF 2700H Training Guide, Getting to know the functions of the 3rd Screen (manual mode): step 10, image 3 of 3
      • Now that we have seen everything the 2nd screen has to offer, let's access the 3rd screen. (Photo 3)
      • On this screen, the operator will only use the strap tensioner; there is no need for the operator to use the positioner or the winder.
      • By pressing the number key 4, the tensioner is activated. This function is used to load the strap to the working position.
      • Lacito Tip: access the manual and see the names of the parts to familiarize yourself with the names.
      • There is no need to activate the positioner and the strap winder.
      Ask FixBot
    1. MF 2700H Training Guide, Loading the spools into the machine: step 11, image 1 of 3 MF 2700H Training Guide, Loading the spools into the machine: step 11, image 2 of 3 MF 2700H Training Guide, Loading the spools into the machine: step 11, image 3 of 3
      • Now, we will load the spools into the machine.
      • The machine was designed to work with 3 spools to allow for faster changeovers and to have additional stock already in the machine. (Photo 2)
      • To begin, take the spool holder shaft, which is located on the back of the machine. (Photo 1)
      • Next, take and align 3 1000-meter spools. (Photo 2)
      • Now, insert the spool holder shaft into the center hole of the spools. (Photo 3)
      Ask FixBot
    2. MF 2700H Training Guide, Installing the coils.: step 12, image 1 of 2 MF 2700H Training Guide, Installing the coils.: step 12, image 2 of 2
      • Place the 3 coils with the support shaft already fitted into the back of the machine, as shown in Photo 1.
      • Lacito tip: Position the coils so that the ribbon unrolls from the top. (Photo 2).
      Ask FixBot
    3. MF 2700H Training Guide, Loading the ribbon into the machine.: step 13, image 1 of 3 MF 2700H Training Guide, Loading the ribbon into the machine.: step 13, image 2 of 3 MF 2700H Training Guide, Loading the ribbon into the machine.: step 13, image 3 of 3
      • Now with the spool in position, place the ribbon into the ribbon guide nozzle. (Photo 1)
      • To do this, use the ribbon from the middle spool, and then pass the ribbon through the ribbon guide nozzle; don't forget to pass the ribbon in vertically. (Photo 1)
      • Pass the ribbon between the pulleys as shown in Photo 2.
      • Next, pass the ribbon along the right side of the central pulley. (Photo 3)
      • Lacito Tip: Lacitos ribbons are paper/plastic, and as shown in the comment above, the ribbon must enter vertically.
      • Continues in the next step.
      Ask FixBot
    4. MF 2700H Training Guide, Installing the Strap into the Tensioner.: step 14, image 1 of 2 MF 2700H Training Guide, Installing the Strap into the Tensioner.: step 14, image 2 of 2
      • Now position the strap in the middle of the tensioner gears, as shown in image sequence 1 and 2.
      • Do not remove the acrylic protective cover from the machine.
      • Keep the strap in position and proceed to the next step to continue the process.
      Ask FixBot
    5. MF 2700H Training Guide, Threading the strap to the starting point.: step 15, image 1 of 3 MF 2700H Training Guide, Threading the strap to the starting point.: step 15, image 2 of 3 MF 2700H Training Guide, Threading the strap to the starting point.: step 15, image 3 of 3
      • Now, keep the strap positioned in the tensioner as in the previous step, and return to the control panel on the 3rd screen (manual mode). (Photo 1)
      • And now hold down key 4 on the numeric keypad; this will start pulling the strap. Let it travel to the end of the white guide arm on the front of the machine. (Photo 2)
      • Now that the strap is positioned, press the ESC key to return to the previous screen (automatic mode). (Photo 3)
      • An operator who is not accustomed to using the machine might not position the strap correctly when placing it in the tensioner, which may cause a buildup of twisted strap in the tensioner. Do not worry, remove it from the tensioner and start over from the beginning.
      Ask FixBot
    6. MF 2700H Training Guide, Adjusting the settings for your packaging.: step 16, image 1 of 3 MF 2700H Training Guide, Adjusting the settings for your packaging.: step 16, image 2 of 3 MF 2700H Training Guide, Adjusting the settings for your packaging.: step 16, image 3 of 3
      • As I mentioned earlier, it is possible to change the machine's parameters and select the best setting for your packaging. So, before you start strapping, let's learn how to change these parameters.
      • When you press the SET key, the cursor will be positioned on the number of wraps value, so use the numeric keys to select the desired value for the number of wraps. Recommended: 3 or 4 wraps. To confirm the changed data, press the ENT key.
      • Upon pressing ENT in the previous step, the cursor will be positioned on the Strap size; enter the desired size in millimeters. Recommended: 70 mm to 80 mm. To confirm the changed data, press the ENT key.
      • With lacito recommendations, the operator has 20 programming options. To discover which one is best for the company, the operator must conduct a study, according to the suggested table on page 11/22 of the manual, where some aspects regarding the packaging are considered.
      • To confirm the changed data, press the ENT key; if there are no changes, press the SET key to exit the programming screen.
      Ask FixBot
    7. MF 2700H Training Guide, Operation: step 17, image 1 of 3 MF 2700H Training Guide, Operation: step 17, image 2 of 3 MF 2700H Training Guide, Operation: step 17, image 3 of 3
      • And now with the strap positioned and the machine programmed, we can start strapping. (Photo 2)
      • Every operator and the company where they work has a way of positioning the machine, has a packaging model and a production output that is peculiar to each company and operator. For this reason, the MF 2700H was designed with settings that will vary from company to company.
      • Do not insert fingers into the strapping actuator zone, as there is a risk of crushing by the positioner. If this occurs, press the emergency button to release the positioner.
      • If you need to turn it off, press the off button (O) (the red one, the brother of the green one).
      • In case of an emergency, press the emergency button; I hope you never need to use this button. (Be responsible).
      • Lacito tip: It is not recommended to use the emergency button to turn off the machine, as it has a short service life; if it is pressed many times unnecessarily, it will present problems.
      Ask FixBot
    8. MF 2700H Training Guide, THE END. (Grand Finale): step 18, image 1 of 1
      • We have reached the end. Leave a comment letting us know what you thought; it is important for us so we can always keep improving.
      • See you later.
      Ask FixBot
Finish Line
3 other people completed this guide.
Special thanks to these translators:
pt en
100%
the is helping us fix the world! Want to contribute?
Start translating ›
Lacito
6,169 Reputation
10 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 30
All Time: 929
