This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓MF 1540 FC usage training
The MF 1540 FC binding machine is semi-automatic equipment that, in addition to binding, also features a configurable winder for your cables and wire harnesses. It is the complete binding machine for those who need agility in their production.
It offers safety, agility, practicality, and easy adjustment with a PLC in Portuguese.
I'm going to share a secret with you: we have the only machine on the market with adjustable binding size, directly saving you money.
To turn on your equipment, you must first connect the power cable to the back of the strapping machine and then to a 220V (volts) 3-pin Brazilian standard 2P+T outlet.
Lacito Tip: When choosing a place to put the strapping machine, choose a safe spot with good space around it and a firm base, which prevents risks to the integrity of the strapping machine and its users—just don't get hurt!
Now, let's look at the position of the Winder.
The Winder is a part located inside the strapping machine, and it is responsible for winding the strap. (Photo 1)
The position of the Winder must always be the same; it must be at 90 degrees, parallel to the machine plate. (Photo 2)
If the Winder is in a position other than the one shown in Photo 2, follow the next step.
For the reassembly of your device, follow these instructions in reverse order.
