Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Lowering the buzzer volume
View statistics:
Past 24 Hours:
Past 7 Days:
25
Past 30 Days:
71
All Time:
224
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This guide documents a change to the buzzer volume on the Nova Digital Family Aerofryer 180170.
The device is equipped with a buzzer that is very loud and quite annoying. I actually read about this in a review as well.
Therefore, I have decided to make the buzzer quieter.
I recommend taking photos during the disassembly. This way, you can check later if in doubt where each screw was located.
    1. Lowering the buzzer volume, Lowering the buzzer volume: step 1, image 1 of 1
      • Use a plastic opening tool to pry open the top cover, which is secured by 4 plastic tabs. Now, 4 screws are accessible from the top and must be removed. Turn the device over and remove 3 additional screws in the charging port opening.
      • This is quite difficult; one of my tabs broke. Pry carefully.
      Ask FixBot
    2. Lowering the buzzer volume: step 2, image 1 of 1
      • The upper housing half can now be lifted off.
      • The display unit is plugged in and secured with a screw. Remove the screw, unplug the display unit, feed it through the upper housing half, and remove it.
      Ask FixBot
    3. Lowering the buzzer volume: step 3, image 1 of 1
      • You now have a PCB in front of you with a buzzer mounted on it. The buzzer is essentially a small 40 ohm speaker without its own electronics, and it has a 100 ohm SMD resistor on the underside of the PCB.
      • I desoldered the buzzer and examined it. You do not need to do this.
      Ask FixBot
    4. Lowering the buzzer volume: step 4, image 1 of 1
      • I have now desoldered the resistance and replaced it with a standard 330 ohm metal oxide resistance. The PCB is secured with 2 screws, which must be released beforehand in order to reach the underside of the PCB. For me, 330 ohms is a good value; with 470 ohms, the buzzer was simply too quiet.
      • This guide shows you how to solder and desolder.
      Ask FixBot
Follow the steps in reverse order to reassemble your device and enjoy the now-quiet buzzer.
Author
with
Thomax
1,053 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 71
All Time: 224
