Shop the Holiday Gift Guide
Loudspeaker Removal
View statistics:
Past 24 Hours:
Past 7 Days:
3
Past 30 Days:
10
All Time:
244
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Loudspeaker Removal
Introduction
Go to step 1 ↓
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Follow this guide to remove the loudspeaker of an Apple iPhone 13 Pro.
Tools
    1. Loudspeaker Removal, Unscrew the loudspeaker: step 1, image 1 of 1
      • Use a Phillips driver to remove the four 1.5 mm screws securing the loudspeaker:
      • Two larger-headed screws
      • Two smaller-headed screws
      Ask FixBot
    2. Loudspeaker Removal, Separate the loudspeaker adhesive: step 2, image 1 of 3 Loudspeaker Removal, Separate the loudspeaker adhesive: step 2, image 2 of 3 Loudspeaker Removal, Separate the loudspeaker adhesive: step 2, image 3 of 3
      • Slide an opening pick between the top edge of the Taptic Engine and the adhesive-backed strip.
      Ask FixBot
    3. Loudspeaker Removal, Remove the loudspeaker: step 3, image 1 of 1
      • Remove the loudspeaker.
      Ask FixBot
Sam Omiotek
101,703 Reputation
289 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 244
