Lorex MC6950 Camera Lens Replacement
    1. Lorex MC6950 Camera Lens Replacement, Camera Lens: step 1, image 1 of 2 Lorex MC6950 Camera Lens Replacement, Camera Lens: step 1, image 2 of 2
      • To remove a bad lens, you must begin by removing the three screw caps and the 15mm JIS 0 screws associated with them located on the plastic containment shell that the camera is in.
      Ask FixBot
    2. Lorex MC6950 Camera Lens Replacement: step 2, image 1 of 2 Lorex MC6950 Camera Lens Replacement: step 2, image 2 of 2
      • Next, the camera must be removed. A metal spudger will be useful to pry this out as it is sealed inside the outer containment shell.
      • Once the camera is removed, remove the wires from the outer containment shell.
      • Be careful. The metal spudger could damage the camera if not handled with care.
      Ask FixBot
    3. Lorex MC6950 Camera Lens Replacement: step 3, image 1 of 2 Lorex MC6950 Camera Lens Replacement: step 3, image 2 of 2
      • With the camera in hand, the circuit board must be separated from the LED containment shell. There is a 5mm JIS 0 screw at every corner of the circuit board.
      • The wires attaching the circuit board to the shell should be removed as well.
      Ask FixBot
    4. Lorex MC6950 Camera Lens Replacement: step 4, image 1 of 1
      • Now the motor housing must be removed from the circuit board first as it is in the way of the screws associated with the lens. There are three 5mm JIS 0 screws located on the lens side of the circuit board to remove the motor.
      Ask FixBot
    5. Lorex MC6950 Camera Lens Replacement: step 5, image 1 of 1
      • The lens has two 5 mm JIS 0 screws located under the motor's previous location. Once these are removed, the lens can be replaced.
      Ask FixBot
Elijah Conlin
379 Reputation
3 Guides authored
IUPUI, Team S2-G2, Harley Fall 2017 Member of IUPUI, Team S2-G2, Harley Fall 2017
IUPUI-HARLEY-F17S2G2
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 27
Past 30 Days: 72
All Time: 1,337
