Shop the Holiday Gift Guide
Lorex LW2742 Back Panel Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
9
All Time:
288
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. Lorex LW2742 Back Panel Replacement, Back Panel: step 1, image 1 of 3 Lorex LW2742 Back Panel Replacement, Back Panel: step 1, image 2 of 3 Lorex LW2742 Back Panel Replacement, Back Panel: step 1, image 3 of 3
      • Remove the battery cover on the back of the LCD monitor by unscrewing one 5mm Phillips #1 screw.
      • Slide the battery out of the housing. Lightly tap the opposite end of the monitor if the battery does not come right out.
      Ask FixBot
    2. Lorex LW2742 Back Panel Replacement: step 2, image 1 of 1
      • Remove the four 6mm Phillips #1 screws on the back of the LCD monitor.
      Ask FixBot
    3. Lorex LW2742 Back Panel Replacement: step 3, image 1 of 2 Lorex LW2742 Back Panel Replacement: step 3, image 2 of 2
      • Using a plastic opening tool, gently separate the back panel from the front panel, working the tool around the panel to disconnect it.
      • Carefully remove the back panel
      • The speaker wire is connected to the motherboard so DO NOT rip back panel away from the monitor.
      Ask FixBot
Author
with
Alex Kusmierz
601 Reputation
5 Guides authored
USF Tampa, Team 16-1, Eyestone Fall 2016 Member of USF Tampa, Team 16-1, Eyestone Fall 2016
USFT-EYESTONE-F16S16G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 288
