Acer Aspire E5-573G Fan Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
82
All Time:
1,729
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
After a while, your laptop fan could get clogged with dust and start overheating or it could get damaged due to excessive usage. Fans remove heat from the interior of the laptop. move heat away from hardware. The main objective of this is to prevent overheating, something electronics is severely sensitive with as well. This guide will help you replace your Acer Aspire E5-573G fan with easy to moderate steps that can be done at home to prevent internal damage to your hardware.
Tools
    1. Acer Aspire E5-573G Fan  Replacement, Fan: step 1, image 1 of 2 Acer Aspire E5-573G Fan  Replacement, Fan: step 1, image 2 of 2
      • Remove the seventeen 5 mm screws from the back cover using a Phillips #00 screwdriver.
      • Be sure to unplug and power down your computer before starting any work.
      Ask FixBot
    2. Acer Aspire E5-573G Fan  Replacement: step 2, image 1 of 2 Acer Aspire E5-573G Fan  Replacement: step 2, image 2 of 2
      • Remove the CD drive located on the side of the laptop.
      Ask FixBot
    3. Acer Aspire E5-573G Fan  Replacement: step 3, image 1 of 1
      • Remove the three 2 mm screws from the disc drive bay using a Phillips #00 screwdriver.
      Ask FixBot
    4. Acer Aspire E5-573G Fan  Replacement: step 4, image 1 of 3 Acer Aspire E5-573G Fan  Replacement: step 4, image 2 of 3 Acer Aspire E5-573G Fan  Replacement: step 4, image 3 of 3
      • Use the spudger to pry open the back cover by sliding it along the sides.
      • Slowly lift the cover upwards.
      • Be gentle while removing the case as it is very thin and might break easily.
      Ask FixBot
    5. Acer Aspire E5-573G Fan  Replacement: step 5, image 1 of 2 Acer Aspire E5-573G Fan  Replacement: step 5, image 2 of 2
      • Apply canned air or use a bellows to remove the dust on the motherboard.
      • Remove the two 2 mm screws holding the fan to the motherboard using Phillips #00 screwdriver.
      • Be gentle unscrewing both screws as the motherboard can get damaged with extra force.
      Ask FixBot
    6. Acer Aspire E5-573G Fan  Replacement: step 6, image 1 of 3 Acer Aspire E5-573G Fan  Replacement: step 6, image 2 of 3 Acer Aspire E5-573G Fan  Replacement: step 6, image 3 of 3
      • Lift out the fan and detach the fan cable from the motherboard.
      • When detaching the cable be careful not to pull the wires. Instead pull the white section that connects the fan to the motherboard.
      Ask FixBot
Lara Mustafa
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 82
All Time: 1,729
