Introduction
This a guide designed to assist you in removing and replacing both speakers present in your Logitech UE Megaboom speaker.
Locate the ends of the speaker.
Put a plastic opening tool in-between the rubber end and the mesh.
Apply a upward force in order to pry open the end.
Apply this procedure to the other side as well.
Pull on white strip to remove battery.
This skipped the step of pulling out the circuit card on the battery charge/aux-in side. Pry up below the gasket next to the large capacitors on both sides.
A faire après les étapes 5 et 6 (pas besoin d’ouvrir l’autre côté de l’enceinte).
Insert a opening tool between the grating and the body of the speaker
Pry up allowing the tabs to pop out of place.
Apply the same procedure to the grating covering the second speaker.
7 other people completed this guide.
7 Comments
Thank you! I was able to glue one of the passive radiators back in place.
Where can I find a speaker replacement? Thanks for your time
I’ve got the same issue. Where can i find the speaker replacement?
For those looking for replacement speakers - either directly from Logitech ( $$$ ) or find a broken one on eBay that’s been water logged or some such thing and recover the speakers from that (since they are waterproof speakers)
Thanks for the article - turns out one of my speaker grills had popped loose and was imitating a blown speaker!
yes! same issue!
i bought a replacement speaker (which i still have if anyone is looking), but it was a speaker grill stopper that had come unglued and vibrated - sounding exactly as if a blown speaker or radiator.
Thank you for this detailed tutorial.
One important thing; do you know where can we buy 2 new speakers ? My UE mega boom fallen down from 4 meters and need to be repaired.
I already dismantle the Megaboom and detected that the 2 speakers are damaged.
Thank you in advance for your answer.
Romain P.
I use a product called Simply Speakers. speaker repair adhesive #MI-3035. Clean off old glue by applying pressure with your thumb and roll glue off the two faces, use alcohol to clean corners. It takes a little bit of rubbing. Apply a small line on mating surface (to much glue does not make a better seal). Put the two surfaces back together. Lay the radiator housing on a flat surface, Get something flat to put on top of the radiator and apply constant pressure for about 12 hrs (A couple of heavy books or anything with weight). I hope this helps someone.
Pry all the way around with the tool as there are “clips” that hold the cap in place all around beneath the cap. Avoid trying to “pull the lid open” from the opening of a half opened lid.
Jamin Hu - Reply
Stop! Before you proceed, notice the comments at the end of the guide. You don't have to take apart both sides or remove the mesh fabric. Remove just the bottom cap (with the aux/charge plug).
Then carefully remove the glue securing the circuit board on the sides and gently pull the board out to reveal the battery under it.
Caleb Kelsay - Reply
FWIW I had no luck opening these caps with the tools I bought on iFixit (plastic pry bar, metal Jimmy). I had a lot more luck using the flat edge of a butter knife! (it still took lots of work on my UE Megaboom 3)
Travis Taylor - Reply
