Introduction
This is a guide designed to assist you in removing and replacing the Logitech UE Megaboom outer mesh.
Locate the ends of the speaker.
Put a opening tool inbetween the rubber end and the mesh.
Apply a upward force in order to pry open the end.
Apply this procedure to the other side as well.
Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
Remove all the rubber you pried off.
Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
Work the plastic retainer out of the channel all the way around the speaker.
Repeat for other side.
