Introduction
This is a guide designed to assist you in removing and replacing the Logitech UE Megaboom Auxiliary and USB Ports.
Locate the ends of the speaker.
Put a plastic opening tool in-between the rubber end and the mesh.
Apply a upward force in order to pry open the end.
Apply this procedure to the other side as well.
Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
Work the plastic retainer out of the channel all the way around the speaker.
Repeat for other side.
Apply an upward force with your thumbs to loosen the end cap.
Grasp the end cap and lift up to seperate it from the base.
Now grasp the plastic on the outside of the rubber seal and pull it out by applying an upward force.
Once the plastic has been removed, pull out the circuit board containing the auxiliary and USB ports.
Hi. Currently i live in paris.
i had bought UE megaboom few months ago whis is a great Bluetooth speaker off course and few days ago I tried to dismantle my speaker just for an experiment but during that I completely messed my speaker, actually the circuit board containing the auxiliary and USB ports got destroyed.
So i want replace that board, Can i buy that circuit board? If yes please tell me where can i find it.
https://www.joesge.com/collections/megab...
They are out of stock currently but will be back in a bit
They're back....
3 other people completed this guide.
10 Comments
How can I purchase this part being replaced thanks
I also need this part due to water damage. Where Do I order this entire motherboard at?
Hello. Did you find the spare part?
Ionut -
I don’t think you can buy the parts new. Try buying a used/broken speaker for parts that has a working part that you need.
I have the same speaker model, with the problem that does not charge the battery. I would like to know if it is a problem with the battery or the charge controller.
Where can I buy the parts
WARNING: As people also noticed in the battery replacement guide comments, when your goal is to only replace the Audio Jack/Micro USB logic board (or the battery) this guide is unnecessarily complicate.
You only have to open one side where the logic board resides.
There are two plastic rings that hold the logic board and rubber seal in position. Using only the plastic opening tool, first remove the inner plastic ring, second remove the outer plastic ring (black color and hidden under the rubber see), third remove the logic board. After the logic board is removed, you can also replace the battery.
The procedure is shown in this video: https://www.youtube.com/watch?v=bwD5BpOk...
Im curious, if my charging port is broken, could I get the power up dock and charge it instead of replacing the circuitboard
Power PCB available on Ebay
Pry all the way around with the tool as there are “clips” that hold the cap in place all around beneath the cap. Avoid trying to “pull the lid open” from the opening of a half opened lid.
Jamin Hu - Reply
Stop! Before you proceed, notice the comments at the end of the guide. You don't have to take apart both sides or remove the mesh fabric. Remove just the bottom cap (with the aux/charge plug).
Then carefully remove the glue securing the circuit board on the sides and gently pull the board out to reveal the battery under it.
Caleb Kelsay - Reply
FWIW I had no luck opening these caps with the tools I bought on iFixit (plastic pry bar, metal Jimmy). I had a lot more luck using the flat edge of a butter knife! (it still took lots of work on my UE Megaboom 3)
Travis Taylor - Reply
