Shop the Holiday Gift Guide
Logitech UE Hyperboom Power Button Board Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
11
Past 7 Days:
49
Past 30 Days:
205
All Time:
1,199
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 4 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace the power button board in a Logitech UE Hyperboom Bluetooth Speaker. The power button is responsible for turning on and off the speaker. The power button can be susceptible to deterioration with repeated use. If your speaker charges visibly, but you get no response from both pressing and holding the power button, this could be a sign of a power button issue.
Before beginning this guide, be sure to power off your speaker.
Tools
    1. Logitech UE Hyperboom Power Button Board Replacement, Handle: step 1, image 1 of 2 Logitech UE Hyperboom Power Button Board Replacement, Handle: step 1, image 2 of 2
      • Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
      • You may need pliers to grip the screws.
      Ask FixBot
    1. Logitech UE Hyperboom Power Button Board Replacement, Top Panel: step 2, image 1 of 2 Logitech UE Hyperboom Power Button Board Replacement, Top Panel: step 2, image 2 of 2
      • Use your hands to carefully pry the plastic cover off of the speaker.
      Ask FixBot
    2. Logitech UE Hyperboom Power Button Board Replacement: step 3, image 1 of 3 Logitech UE Hyperboom Power Button Board Replacement: step 3, image 2 of 3 Logitech UE Hyperboom Power Button Board Replacement: step 3, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the ten 11.7mm screws on the top panel.
      • Remove the top panel to access the internal components.
      • Use a metal spudger to completely disconnect the top panel.
      Ask FixBot
    1. Logitech UE Hyperboom Power Button Board Replacement, Power Button Board: step 4, image 1 of 3 Logitech UE Hyperboom Power Button Board Replacement, Power Button Board: step 4, image 2 of 3 Logitech UE Hyperboom Power Button Board Replacement, Power Button Board: step 4, image 3 of 3
      • Use the Phillips #0 screwdriver to unscrew the seven 6.5mm screws on the circuit board.
      • Use a metal spudger to disconnect the power button board from the panel.
      Ask FixBot
Author
with
Ethan Abbott
886 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 49
Past 30 Days: 205
All Time: 1,199
