Shop the Holiday Gift Guide
Logitech UE Hyperboom DC Power Socket Replacement
View statistics:
Past 24 Hours:
7
Past 7 Days:
41
Past 30 Days:
145
All Time:
610
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace the DC Power Socket in a Logitech UE Hyperboom Bluetooth Speaker. The DC Power Socket is essential to charge the speaker's battery. The DC Power Socket can be susceptible to deterioration after repeated use. If cords cannot fully plug into the socket, or if speaker is not charging, then the potential cause could be a faulty DC power socket.
Before beginning this guide be sure to power off your speaker.
Tools
    1. Logitech UE Hyperboom DC Power Socket Replacement, Handle: step 1, image 1 of 2 Logitech UE Hyperboom DC Power Socket Replacement, Handle: step 1, image 2 of 2
      • Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
      • You may need pliers to grip the screws.
      Ask FixBot
    1. Logitech UE Hyperboom DC Power Socket Replacement, Bottom Panel: step 2, image 1 of 2 Logitech UE Hyperboom DC Power Socket Replacement, Bottom Panel: step 2, image 2 of 2
      • Use the Jimmy to pry off the four rubber feet on the bottom of the speaker.
      Ask FixBot
    2. Logitech UE Hyperboom DC Power Socket Replacement: step 3, image 1 of 3 Logitech UE Hyperboom DC Power Socket Replacement: step 3, image 2 of 3 Logitech UE Hyperboom DC Power Socket Replacement: step 3, image 3 of 3
      • Use a Phillips #0 screwdriver to remove all twelve 11.7mm screws from the bottom panel of the speaker.
      • Pull the panel off to access the internal components.
      Ask FixBot
    1. Logitech UE Hyperboom DC Power Socket Replacement, DC Power Socket: step 4, image 1 of 3 Logitech UE Hyperboom DC Power Socket Replacement, DC Power Socket: step 4, image 2 of 3 Logitech UE Hyperboom DC Power Socket Replacement, DC Power Socket: step 4, image 3 of 3
      • Unscrew the top 11.7m screw on the DC Power Socket panel using the Phillips #0 screwdriver.
      • Use the Jimmy to pry the panel away from the speaker, then disconnect the power cables from the daughterboard.
      Ask FixBot
    2. Logitech UE Hyperboom DC Power Socket Replacement: step 5, image 1 of 2 Logitech UE Hyperboom DC Power Socket Replacement: step 5, image 2 of 2
      • Remove the four 7.9mm screws from the daughterboard with the Phillips #0 screwdriver.
      • Pull the circuit board away from the panel.
      Ask FixBot
Author
with
Ethan Abbott
886 Reputation
8 Guides authored
1 Guide Comment
G'day I've got the 2024 version that has a broken charging port and can't find a PCB replacement anywhere I'm in New Zealand probably why but do you guys reckon I could just swap it out with the older version of the charging board since there available.
Ethan Donaldson - Reply Share
Past 24 Hours: 7
Past 7 Days: 41
Past 30 Days: 145
All Time: 610
