Logitech UE Hyperboom Bottom Panel Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
66
All Time:
228
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this prerequisite guide as an initial step before accessing the internal components of the speaker.
Tools
    1. Logitech UE Hyperboom Bottom Panel Replacement, Handle: step 1, image 1 of 2 Logitech UE Hyperboom Bottom Panel Replacement, Handle: step 1, image 2 of 2
      • Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
      • You may need pliers to grip the screws.
      Ask FixBot
    1. Logitech UE Hyperboom Bottom Panel Replacement, Bottom Panel: step 2, image 1 of 2 Logitech UE Hyperboom Bottom Panel Replacement, Bottom Panel: step 2, image 2 of 2
      • Use the Jimmy to pry off the four rubber feet on the bottom of the speaker.
      Ask FixBot
    2. Logitech UE Hyperboom Bottom Panel Replacement: step 3, image 1 of 3 Logitech UE Hyperboom Bottom Panel Replacement: step 3, image 2 of 3 Logitech UE Hyperboom Bottom Panel Replacement: step 3, image 3 of 3
      • Use a Phillips #0 screwdriver to remove all twelve 11.7mm screws from the bottom panel of the speaker.
      • Pull the panel off to access the internal components.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 66
All Time: 228
