Shop the Holiday Gift Guide
Logitech UE Hyperboom Battery Replacement
View statistics:
Past 24 Hours:
13
Past 7 Days:
47
Past 30 Days:
192
All Time:
901
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 7 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace the battery in a Logitech UE Hyperboom Bluetooth Speaker. The battery is what supplies power to every component of the speaker. Batteries generally are the first component to fail in a device, so it is likely that the battery is the source of an issue. If your speaker shuts down unexpectedly, refuses to power on without being plugged in, or shows extremely reduced playtime, a battery replacement might be necessary.
Before beginning this guide, be sure to power off your speaker.
Tools
    1. Logitech UE Hyperboom Battery Replacement, Handle: step 1, image 1 of 2 Logitech UE Hyperboom Battery Replacement, Handle: step 1, image 2 of 2
      • Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
      • You may need pliers to grip the screws.
      Ask FixBot
    1. Logitech UE Hyperboom Battery Replacement, Top Panel: step 2, image 1 of 2 Logitech UE Hyperboom Battery Replacement, Top Panel: step 2, image 2 of 2
      • Use your hands to carefully pry the plastic cover off of the speaker.
      Ask FixBot
    2. Logitech UE Hyperboom Battery Replacement: step 3, image 1 of 3 Logitech UE Hyperboom Battery Replacement: step 3, image 2 of 3 Logitech UE Hyperboom Battery Replacement: step 3, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the ten 11.7mm screws on the top panel.
      • Remove the top panel to access the internal components.
      • Use a metal spudger to completely disconnect the top panel.
      Ask FixBot
    1. Logitech UE Hyperboom Battery Replacement, Battery: step 4, image 1 of 3 Logitech UE Hyperboom Battery Replacement, Battery: step 4, image 2 of 3 Logitech UE Hyperboom Battery Replacement, Battery: step 4, image 3 of 3
      • Unplug the battery cord from the motherboard.
      • Remove the battery from the battery compartment.
      Ask FixBot
Author
with
Ethan Abbott
886 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 13
Past 7 Days: 47
Past 30 Days: 192
All Time: 901
