UE Boom 2 Lithium Battery Replacement
  1. UE Boom 2 Lithium Battery Replacement, D-ring: step 1, image 1 of 1
    • Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
  2. UE Boom 2 Lithium Battery Replacement: step 2, image 1 of 2 UE Boom 2 Lithium Battery Replacement: step 2, image 2 of 2
    • Lift the handle on the D-ring and unscrew it.
    • Remove the D-ring.
  3. UE Boom 2 Lithium Battery Replacement, Bluetooth Adapter: step 3, image 1 of 1
    • Any repairs made from this point forward will void your device's warranty.
    • Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
  4. UE Boom 2 Lithium Battery Replacement: step 4, image 1 of 3 UE Boom 2 Lithium Battery Replacement: step 4, image 2 of 3 UE Boom 2 Lithium Battery Replacement: step 4, image 3 of 3
    • Find the part of the casing that covers the volume controls. Wedge the metal spudger under this and pry open all of the tabs as in the previous step.
    • Repeat for the bottom of the speaker and pry the casing open with your fingers.
  5. UE Boom 2 Lithium Battery Replacement: step 5, image 1 of 2 UE Boom 2 Lithium Battery Replacement: step 5, image 2 of 2
    • Using the Phillips J0 head screwdriver, unscrew the four silver 9 mm screws.
    • Do the same for the two black 7 mm screws.
  6. UE Boom 2 Lithium Battery Replacement: step 6, image 1 of 3 UE Boom 2 Lithium Battery Replacement: step 6, image 2 of 3 UE Boom 2 Lithium Battery Replacement: step 6, image 3 of 3
    • This next step involves the use of a hot soldering iron. Remember to be careful during this step since it can be easy to burn yourself.
    • Using a soldering iron, de-solder the two ends of the switch plate.
  7. UE Boom 2 Lithium Battery Replacement: step 7, image 1 of 1
    • With the switch plate disconnected, remove it and your device should now look like this.
  8. UE Boom 2 Lithium Battery Replacement, Lithium Battery: step 8, image 1 of 1
    • With a metal spudger, pry open the tabs on the speaker sleeve along the length of the speaker.
  9. UE Boom 2 Lithium Battery Replacement: step 9, image 1 of 1
    • Use a plastic opening tool to pry the sleeve off from the bottom of the speaker.
  10. UE Boom 2 Lithium Battery Replacement: step 10, image 1 of 3 UE Boom 2 Lithium Battery Replacement: step 10, image 2 of 3 UE Boom 2 Lithium Battery Replacement: step 10, image 3 of 3
    • Peel off the sleeve.
  11. UE Boom 2 Lithium Battery Replacement: step 11, image 1 of 2 UE Boom 2 Lithium Battery Replacement: step 11, image 2 of 2
    • Use a Phillips 1 screwdriver to unscrew the eight black 14 mm screws along the length of the casing.
  12. UE Boom 2 Lithium Battery Replacement: step 12, image 1 of 2 UE Boom 2 Lithium Battery Replacement: step 12, image 2 of 2
    • With the screws removed, pry open the casing to be able to get to the components inside.
    • Try prying the case open from one of the ends if that is easier.
  13. UE Boom 2 Lithium Battery Replacement: step 13, image 1 of 2 UE Boom 2 Lithium Battery Replacement: step 13, image 2 of 2
    • With a Phillips #00 screwdriver, unscrew two 5.6 mm screws from the rectangular shaped circuit board.
  14. UE Boom 2 Lithium Battery Replacement: step 14, image 1 of 1
    • With the Phillips #2 screwdriver, unscrew the 9.9 mm screw from the larger circuit board surrounding the speaker.
  15. UE Boom 2 Lithium Battery Replacement: step 15, image 1 of 1
    • Once all of the screws are gone, you should be able to remove the circuit boards and find the battery.
  16. UE Boom 2 Lithium Battery Replacement: step 16, image 1 of 2 UE Boom 2 Lithium Battery Replacement: step 16, image 2 of 2
    • Remove the battery by pulling it from the terminal as marked in the picture.
Jose Cruz Arinaga
1,003 Reputation
3 Guides authored
Cal Poly, Team 4-1, Maness Fall 2015 Member of Cal Poly, Team 4-1, Maness Fall 2015
CPSU-MANESS-F15S4G1
4 Members
22 Guides authored
Past 24 Hours: 37
Past 7 Days: 280
Past 30 Days: 1,315
All Time: 115,942
