Logitech RS Shifter & Handbrake Midframe Replacement
    1. Logitech RS Shifter & Handbrake Midframe Replacement, Before you begin: step 1, image 1 of 3 Logitech RS Shifter & Handbrake Midframe Replacement, Before you begin: step 1, image 2 of 3 Logitech RS Shifter & Handbrake Midframe Replacement, Before you begin: step 1, image 3 of 3
      • Before you begin your repair:
      • Unplug the shifter's USB cable.
      • Completely unmount the shifter from the clamp and remove any accessories so you're left with just the shifter.
      • Use a 4.0 mm hex screwdriver to remove the 31 mm‑long screws securing the shifter to the clamp.
      Ask FixBot
    1. Logitech RS Shifter & Handbrake Midframe Replacement, Remove the handle: step 2, image 1 of 3 Logitech RS Shifter & Handbrake Midframe Replacement, Remove the handle: step 2, image 2 of 3 Logitech RS Shifter & Handbrake Midframe Replacement, Remove the handle: step 2, image 3 of 3
      • Twist the handle counterclockwise to unscrew and remove it.
      • Grip the knurled section of the handle, not the collar at the base.
      Ask FixBot
    1. Logitech RS Shifter & Handbrake Midframe Replacement, Remove the top cover: step 3, image 1 of 2 Logitech RS Shifter & Handbrake Midframe Replacement, Remove the top cover: step 3, image 2 of 2
      • Use a 2.5 mm hex screwdriver to remove the four 11 mm‑long screws securing the top cover.
      Ask FixBot
    2. Logitech RS Shifter & Handbrake Midframe Replacement: step 4, image 1 of 2 Logitech RS Shifter & Handbrake Midframe Replacement: step 4, image 2 of 2
      • Lift the top cover straight up to remove it—the metal shift gate is sitting loosely in the cover.
      Ask FixBot
    1. Logitech RS Shifter & Handbrake Midframe Replacement, Remove the chassis: step 5, image 1 of 2 Logitech RS Shifter & Handbrake Midframe Replacement, Remove the chassis: step 5, image 2 of 2
      • Remove the eight screws securing the chassis:
      • Four 10 mm‑long 2.5 mm hex screws
      • Four 12 mm‑long Phillips screws
      Ask FixBot
    2. Logitech RS Shifter & Handbrake Midframe Replacement: step 6, image 1 of 2 Logitech RS Shifter & Handbrake Midframe Replacement: step 6, image 2 of 2
      • Lift the chassis straight up and remove it.
      Ask FixBot
    1. Logitech RS Shifter & Handbrake Midframe Replacement, Remove the midframe: step 7, image 1 of 2 Logitech RS Shifter & Handbrake Midframe Replacement, Remove the midframe: step 7, image 2 of 2
      • Use a long-shank Phillips screwdriver to remove the six 12 mm‑long screws securing the midframe.
      • During reassembly, make sure you install the screws through the plastic midframe, not the large holes on the metal baseplate.
      Ask FixBot
    2. Logitech RS Shifter & Handbrake Midframe Replacement: step 8, image 1 of 2 Logitech RS Shifter & Handbrake Midframe Replacement: step 8, image 2 of 2
      • Lift the midframe straight up and remove it.
      Ask FixBot
Spencer Day
205,941 Reputation
1,267 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 77
All Time: 171
