Logitech RS Shifter & Handbrake Chassis Replacement
  1. Logitech RS Shifter & Handbrake Chassis Replacement, Before you begin: step 1, image 1 of 3 Logitech RS Shifter & Handbrake Chassis Replacement, Before you begin: step 1, image 2 of 3 Logitech RS Shifter & Handbrake Chassis Replacement, Before you begin: step 1, image 3 of 3
    • Before you begin your repair:
    • Unplug the shifter's USB cable.
    • Completely unmount the shifter from the clamp and remove any accessories so you're left with just the shifter.
    • Use a 4.0 mm hex screwdriver to remove the 31 mm‑long screws securing the shifter to the clamp.
    Ask FixBot
  2. Logitech RS Shifter & Handbrake Chassis Replacement, Remove the handle: step 2, image 1 of 3 Logitech RS Shifter & Handbrake Chassis Replacement, Remove the handle: step 2, image 2 of 3 Logitech RS Shifter & Handbrake Chassis Replacement, Remove the handle: step 2, image 3 of 3
    • Twist the handle counterclockwise to unscrew and remove it.
    • Grip the knurled section of the handle, not the collar at the base.
    Ask FixBot
  3. Logitech RS Shifter & Handbrake Chassis Replacement, Remove the top cover: step 3, image 1 of 2 Logitech RS Shifter & Handbrake Chassis Replacement, Remove the top cover: step 3, image 2 of 2
    • Use a 2.5 mm hex screwdriver to remove the four 11 mm‑long screws securing the top cover.
    Ask FixBot
  4. Logitech RS Shifter & Handbrake Chassis Replacement: step 4, image 1 of 2 Logitech RS Shifter & Handbrake Chassis Replacement: step 4, image 2 of 2
    • Lift the top cover straight up to remove it—the metal shift gate is sitting loosely in the cover.
    Ask FixBot
  5. Logitech RS Shifter & Handbrake Chassis Replacement, Remove the chassis: step 5, image 1 of 2 Logitech RS Shifter & Handbrake Chassis Replacement, Remove the chassis: step 5, image 2 of 2
    • Remove the eight screws securing the chassis:
    • Four 10 mm‑long 2.5 mm hex screws
    • Four 12 mm‑long Phillips screws
    Ask FixBot
  6. Logitech RS Shifter & Handbrake Chassis Replacement: step 6, image 1 of 2 Logitech RS Shifter & Handbrake Chassis Replacement: step 6, image 2 of 2
    • Lift the chassis straight up and remove it.
    Ask FixBot
Spencer Day
196,499 Reputation
1,243 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 50
All Time: 63
