Logitech RS H-Shifter Top Cover Replacement
    1. Logitech RS H-Shifter Top Cover Replacement, Before you begin: step 1, image 1 of 3 Logitech RS H-Shifter Top Cover Replacement, Before you begin: step 1, image 2 of 3 Logitech RS H-Shifter Top Cover Replacement, Before you begin: step 1, image 3 of 3
      • Before you begin your repair:
      • Unplug the H‑Shifter's USB cable.
      • Completely unmount the shifter from the clamp and remove any accessories so you're left with just the shifter.
      • Use a 4.0 mm hex screwdriver to remove the 31 mm‑long screws securing the shifter to the clamp.
      Ask FixBot
    1. Logitech RS H-Shifter Top Cover Replacement, Remove the shift knob: step 2, image 1 of 3 Logitech RS H-Shifter Top Cover Replacement, Remove the shift knob: step 2, image 2 of 3 Logitech RS H-Shifter Top Cover Replacement, Remove the shift knob: step 2, image 3 of 3
      • Twist the shift knob counterclockwise to unscrew and remove it.
      Ask FixBot
    1. Logitech RS H-Shifter Top Cover Replacement, Remove the top cover: step 3, image 1 of 2 Logitech RS H-Shifter Top Cover Replacement, Remove the top cover: step 3, image 2 of 2
      • Use a 2.5 mm hex screwdriver to remove the four 12 mm‑long screws securing the top cover.
      Ask FixBot
    2. Logitech RS H-Shifter Top Cover Replacement: step 4, image 1 of 2 Logitech RS H-Shifter Top Cover Replacement: step 4, image 2 of 2
      • Lift the top cover straight up to remove it.
      • The metal shift gate is sitting loosely in the cover.
      Ask FixBot
Spencer Day
205,151 Reputation
1,266 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 21
Past 30 Days: 43
All Time: 118
