Logitech Pure-Fi Anywhere 2 Battery Replacement
  1. Logitech Pure-Fi Anywhere 2 Battery Replacement, Loosening cosmetic plastic cover: step 1, image 1 of 2 Logitech Pure-Fi Anywhere 2 Battery Replacement, Loosening cosmetic plastic cover: step 1, image 2 of 2
    • To avoid damage to the outside of the casing create a first opening with a plastic opening tool.
    • Insert the metal spudger in the opening you just created.
  2. Logitech Pure-Fi Anywhere 2 Battery Replacement: step 2, image 1 of 2 Logitech Pure-Fi Anywhere 2 Battery Replacement: step 2, image 2 of 2
    • Now work your way along all sides, cuting through the glue with the spudger. The glue is all over so make make sure to go deep enough under the cover with the spudger.
  3. Logitech Pure-Fi Anywhere 2 Battery Replacement, Removing cosmetic cover: step 3, image 1 of 3 Logitech Pure-Fi Anywhere 2 Battery Replacement, Removing cosmetic cover: step 3, image 2 of 3 Logitech Pure-Fi Anywhere 2 Battery Replacement, Removing cosmetic cover: step 3, image 3 of 3
    • Remove the plastic cover to get access to the screws.
    • The glue will still stick when reassambling the Pure-Fi Anywhere.
  4. Logitech Pure-Fi Anywhere 2 Battery Replacement, Unscrew front cover: step 4, image 1 of 1
    • Remove the eight Phillips screws securing the front cover to the back cover.
  5. Logitech Pure-Fi Anywhere 2 Battery Replacement, Open the device: step 5, image 1 of 2 Logitech Pure-Fi Anywhere 2 Battery Replacement, Open the device: step 5, image 2 of 2
    • Lift the front cover up away from the back cover. Do not pull them apart to far though as the battery is secured to the back cover while everything else is secured to the front cover.
    • Chances are that the wires running from the battery itself to the connector are firmly tucked behind the battery making it hard to get a grip on the connecter so just leave it connected for now.
  6. Logitech Pure-Fi Anywhere 2 Battery Replacement, Remove battery cover: step 6, image 1 of 3 Logitech Pure-Fi Anywhere 2 Battery Replacement, Remove battery cover: step 6, image 2 of 3 Logitech Pure-Fi Anywhere 2 Battery Replacement, Remove battery cover: step 6, image 3 of 3
    • Remove the two Phillips screws securing the battery cover.
    • Remove the battery cover to finaly get access to the battery.
    • Now you can get a good grip on the battery connector to disconnect it.
    • Replace with new battery!
  7. Logitech Pure-Fi Anywhere 2 Battery Replacement: step 7, image 1 of 1
    • Chances are your replacement battery doesn't have foam tape taped around it. If you don't have a roll of foam tape lying around at home just gentlypeel off the tape from the old battery and aply it to the new battery. This will ensure that the battery will firmly secured under the battery cover.
EricV
758 Reputation
2 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 64
All Time: 10,048
