Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement
      • Turn off the mouse before beginning disassembly.
      • Flip the mouse over so the sensor and power switch are facing you.
      • Insert a plastic spudger between each slider and the plastic mouse base. Pry the adhesive slider off of the base to reveal the screw wells.
      • A careful amount of heat applied directly to the slider before removal can help ensure they are reusable.
      • The mouse sliders will likely be unusable after removing them, they will need to be replaced.
      Ask FixBot
    1. Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Lift the top off the mouse: step 2, image 1 of 3 Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Lift the top off the mouse: step 2, image 2 of 3 Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Lift the top off the mouse: step 2, image 3 of 3
      • Remove the five Phillips screws from the bottom of the mouse.
      • Flip the mouse over, holding both the base and the top to avoid it falling apart.
      • Lift the top of the mouse straight up and away from the base. Once it is clear from the screw wells, rotate the top to lay it on its primary button side.
      • A ribbon cable holds these pieces of the mouse together -- be careful during this step to avoid damaging it!
      Ask FixBot
    2. Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Free the top from the base: step 3, image 1 of 2 Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Free the top from the base: step 3, image 2 of 2
      • Use a plastic spudger to lift both sides of the ribbon cable lock on the base of the mouse.
      • Lift the ribbon cable straight out of its socket on the base.
      Ask FixBot
    3. Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement: step 4, image 1 of 1
      • Flip the top of the mouse over to view its interior.
      • Remove the five Philips screws holding the top grippy facade to the top. There is no need to remove the screw nearest the DPI switching button located on the top of the mouse. Note, these 5 screws are a different (shorter) length than the others, so store them separately.
      Ask FixBot
    4. Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Loosen the grippy facade: step 5, image 1 of 3 Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Loosen the grippy facade: step 5, image 2 of 3 Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Loosen the grippy facade: step 5, image 3 of 3
      • Flip the top of the mouse over so it is in the orientation it would be during normal use. Turn the top of the mouse so the main buttons and wheel are facing you.
      • Insert a plastic spudger into the seam in the grippy facade at the front of the mouse, nearest the right side of the buttons. It should snap out of place.
      • Apply pressure to the bottom edge of the facade under the middle of the mouse buttons. It should snap further out of place.
      • Flip the top of the mouse over so the main buttons and mouse wheel are facing the work surface.
      • Insert a plastic spudger into the seam between the grippy facade and the plastic base of the mouse at its right side. The facade should almost completely snap out of place.
      Ask FixBot
    5. Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Remove grippy facade: step 6, image 1 of 1
      • Flip the top of the mouse over so it is in the orientation it would be during normal operation. Turn it so the main buttons and wheel are facing away from you.
      • Grab the grippy facade near the DPI switcher button and wiggle it left and right while pulling it away from the top of the mouse.
      Ask FixBot
    6. Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Remove mouse buttons: step 7, image 1 of 3 Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Remove mouse buttons: step 7, image 2 of 3 Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Remove mouse buttons: step 7, image 3 of 3
      • Turn the top of the mouse so the main buttons and wheel are facing you.
      • Remove the four wide Phillips screws holding the mouse buttons to the top chassis.
      • Insert a plastic spudger between the left side of the left mouse button and the chassis. Gently pry the button to free it. It should pop off, but may require a light push to the right to fully separate.
      • Grab the right mouse button to the left of the mouse wheel. Pull it to the left and away from the chassis.
      Ask FixBot
    7. Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Remove wheel assembly: step 8, image 1 of 2 Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Remove wheel assembly: step 8, image 2 of 2
      • Remove the four Phillips screws holding the mouse wheel assembly to the top chassis.
      • Grab the mouse assembly by the wheel or the plastic and pull it directly away from the chassis.
      • The mouse wheel is able to freely pivot 180º from its plastic assembly. Be careful to hold this assembly together as you turn it to set it down.
      Ask FixBot
    8. Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Remove DPI switcher button ribbon cable: step 9, image 1 of 2 Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Remove DPI switcher button ribbon cable: step 9, image 2 of 2
      • Use a plastic spudger to pivot the lock on the ribbon cable connector for the DPI switcher button.
      • Lift the ribbon cable out of its connector.
      Ask FixBot
    9. Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Free the left click microswitch board: step 10, image 1 of 2 Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Free the left click microswitch board: step 10, image 2 of 2
      • Remove the two Phillips screws securing the left click microswitch board to the top chassis.
      • Gently pull out and pivot the board so it is free from the chassis.
      • This small board is still attached to the main top chassis motherboard. Don't move the small board any more than is necessary to dislodge it from its plastic holders.
      Ask FixBot
    10. Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Unscrew top chassis motherboard: step 11, image 1 of 1
      • Remove the single Phillips screw holding the top chassis motherboard to the top chassis.
      Ask FixBot
    11. Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Remove navigation button ribbon cable: step 12, image 1 of 1
      • Use a plastic spudger to pivot the lock on the ribbon cable connector for the navigation button assembly, then lift the ribbon cable out of the connector.
      Ask FixBot
    12. Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Remove top chassis motherboard: step 13, image 1 of 1
      • Grab the top chassis motherboard by the right click microswitch. Pull it toward you to free it from its pegs in the chassis, then lift it directly up and out of the top chassis.
      • The top chassis motherboard still has its main ribbon cable attached. Be careful to lift it directly out of the chassis without shearing the cable.
      Ask FixBot
    13. Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Prepare top chassis motherboard for soldering: step 14, image 1 of 1
      • Use a plastic spudger to pivot the lock on the ribbon cable connector, then remove the ribbon cable from the connector.
      Ask FixBot
    14. Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Desolder each microswitch: step 15, image 1 of 1
      Tool used on this step:
      Desoldering Pump
      $3.99
      Buy
      • Apologies for not having more detailed images... I don't have a good setup for photography while using both hands.
      • Add some new solder to each of the three terminals on one microswitch.
      • While pulling the microswitch away from the board, heat its three terminals. The switch should come free.
      • If you have trouble with this method, you may have better luck by removing as much solder as possible using solder wick and a solder sucker before pulling the microswitch away. However you do it, all three terminals will need to be warm enough to melt their solder at the same time.
      • Clean the terminals of any excess solder using a solder sucker and solder braid. The holes in the board should be clearly visible, it should be easy to insert your new switches.
      • Double check to make sure each solder pad on the bottom of the circuit board has continuity to the trace surrounding its corresponding hole on the top of the circuit board in case you separated them while extracting the old switch.
      • Repeat these steps for the other microswitch.
      Ask FixBot
    15. Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement, Insert and solder new microswitches: step 16, image 1 of 1
      • Insert the switch contacts through the holes in the board.
      • Mind the switch's orientation! The actuator will go toward the right of the motherboard in this image.
      • Solder one switch contact to the board while pressing the switch into the board. Allow the switch to cool.
      • Ensure the switch is flush with the board, otherwise the mouse buttons will not click correctly. But also do not put excessive pressure on the plastic.
      • Solder the remaining contacts to the board, allowing the switch to cool each time.
      Ask FixBot
To reassemble your device, follow steps 1-14 in reverse order.
120 other people completed this guide.
May D
2,767 Reputation
3 Guides authored
72 Guide Comments
Thanks! This is perfect.
Sébastien Dolard - Reply Share
Super guide with details, done step by step, picture by picture, my MX Vertical working great now :) THANK YOU !!!!!
Chris mmhk - Reply Share
Thanks for this guide !!!
Regarding Logitech quality: it’s a shame that such an expensive mouse (paid 100€ !) has only “normal” micro switches (10M)
I’ve also replaced the switches by a 50M variant (OMRON D2FC-F-7N(50M))
Michael Katzenberger - Reply Share
Woah 100 bucks sounds like a theft. I had it for 35€ on Amazon on nov 2019.
Andrea Collet - Reply Share
Great work on the guide. My mouse wouldn’t drag reliably anymore, all better now!
I wouldn’t classify this as difficult btw, medium maybe but everything is fairly easy to open.
Just one thing for anyone attempting:
-The first, big ribbon cable to the big mainboard is slide-to-unlock
-All other ribbon cables on the top half are tilt-to-unlock (lever style).
I didn’t look/read carefully and broke the latch on one of them trying to slide it…
Laurens Corijn - Reply Share
Past 24 Hours: 58
Past 7 Days: 373
Past 30 Days: 1,784
All Time: 95,581
