Shop the Holiday Gift Guide
Logitech MX Master 3S Clicker Replacement
Views: 18K
View statistics:
Past 24 Hours:
230
Past 7 Days:
1,297
Past 30 Days:
5,447
All Time:
17,786
Comments: 8
3 comments on steps, 5 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace a worn or unresponsive clicker switch in a Logitech MX Master 3 or MX Master 3S mouse. The clicker switch is a small mechanical component beneath the primary mouse buttons, and it's one of the first parts to wear out with heavy use.
Common symptoms of a failing clicker include: double-clicking when you only press once, clicks that don't register at all, a mushy or inconsistent feel when pressing the button, or a left/right click that feels noticeably different from when the mouse was new. If you're experiencing any of these, a clicker replacement is likely the fix.
Before you begin, be aware of the following hazards:
  • Static discharge — The MX Master 3/3S contains sensitive electronics. Work on a non-carpeted surface and consider using an anti-static wrist strap to avoid damaging components.
  • Heat — Since the replacement involves soldering, use care around the PCB. Excess heat can lift pads or damage nearby components.
  • Small parts — The mouse contains tiny screws and clips that are easy to lose. Work over a tray or mat and keep a container nearby for hardware.
Tools and skills you'll need: This repair requires basic soldering skills — you'll need to desolder the old switch and solder in the replacement. If you've never soldered before, practice on scrap electronics first.
Parts
Tools
    1. Logitech MX Master 3S Clicker Replacement, Clicker: step 1, image 1 of 2 Logitech MX Master 3S Clicker Replacement, Clicker: step 1, image 2 of 2
      • Flip the mouse over and power the device off.
      Ask FixBot
    2. Logitech MX Master 3S Clicker Replacement: step 2, image 1 of 3 Logitech MX Master 3S Clicker Replacement: step 2, image 2 of 3 Logitech MX Master 3S Clicker Replacement: step 2, image 3 of 3
      • Using a T4 Torx screwdriver, remove the top screw in the center area below the clicker surfaces.
      • Using an opening tool, lift and remove the skate pads.
      Ask FixBot
    3. Logitech MX Master 3S Clicker Replacement: step 3, image 1 of 2 Logitech MX Master 3S Clicker Replacement: step 3, image 2 of 2
      • Using a Phillips screwdriver, remove the screws holding the footing in place.
      Ask FixBot
    4. Logitech MX Master 3S Clicker Replacement: step 4, image 1 of 3 Logitech MX Master 3S Clicker Replacement: step 4, image 2 of 3 Logitech MX Master 3S Clicker Replacement: step 4, image 3 of 3
      • Insert a plastic opening tool into the seam between the top shell and the bottom case along the side of the mouse.
      • Once all clips are released, carefully lift the top shell, but do not remove it completely yet—internal cables are still attached.
      • Support the top shell with one hand so the cable is not strained.
      • Gently disconnect the ribbon cable (or small connector) linking the top shell to the main board.
      Ask FixBot
    5. Logitech MX Master 3S Clicker Replacement: step 5, image 1 of 3 Logitech MX Master 3S Clicker Replacement: step 5, image 2 of 3 Logitech MX Master 3S Clicker Replacement: step 5, image 3 of 3
      • Remember this cable orientation for reassembly.
      • Using a Phillips screwdriver, remove the battery by unscrewing the screws at each corner.
      Ask FixBot
    6. Logitech MX Master 3S Clicker Replacement: step 6, image 1 of 3 Logitech MX Master 3S Clicker Replacement: step 6, image 2 of 3 Logitech MX Master 3S Clicker Replacement: step 6, image 3 of 3
      • Remove the mouse wheel by unscrewing the screws from the bracket to the motherboard.
      • Remove the screws mounting the motherboard to the mouse bottom shell, and remove the motherboard.
      • Release the old clicker/switch by desoldering.
      Ask FixBot
    7. Logitech MX Master 3S Clicker Replacement: step 7, image 1 of 3 Logitech MX Master 3S Clicker Replacement: step 7, image 2 of 3 Logitech MX Master 3S Clicker Replacement: step 7, image 3 of 3
      • With the old clicker/switch removed, remember to clean your service area on the motherboard before inserting the replacement clicker/switch.
      • Use the soldering iron to solder the clickers securely.
      • Be careful using the soldering iron as it gets very hot. Avoid placing it directly on or near things that could be burned.
      Ask FixBot
    8. Logitech MX Master 3S Clicker Replacement: step 8, image 1 of 3 Logitech MX Master 3S Clicker Replacement: step 8, image 2 of 3 Logitech MX Master 3S Clicker Replacement: step 8, image 3 of 3
      • Reinsert the motherboard into the mouse housing and secure it in place by rescrewing the screws.
      • Reseat the mouse wheel removed earlier back onto the motherboard bracket.
      • Reinsert the battery and fasten down the corner screws removed previously.
      Ask FixBot
    9. Logitech MX Master 3S Clicker Replacement: step 9, image 1 of 3 Logitech MX Master 3S Clicker Replacement: step 9, image 2 of 3 Logitech MX Master 3S Clicker Replacement: step 9, image 3 of 3
      • Reconnect the mouse top shell ribbon. Handle gently to avoid damaging the ribbon connector.
      • Reassemble the mouse shell back in place. All seams should be aligned when properly in place.
      Ask FixBot
    10. Logitech MX Master 3S Clicker Replacement: step 10, image 1 of 3 Logitech MX Master 3S Clicker Replacement: step 10, image 2 of 3 Logitech MX Master 3S Clicker Replacement: step 10, image 3 of 3
      • Screw in each bottom plate screw to secure the device in place.
      • Apply mouse skate pads carefully aligned with the cutout. Remove plastic protector covers.
      • New mouse skates are recommended. This is optional, however.
      Ask FixBot
    11. Logitech MX Master 3S Clicker Replacement: step 11, image 1 of 1
      • Power on the mouse and open the Logi Options+ software to confirm it's properly connecting and functioning.
      Ask FixBot
Your Logitech MX Master 3S is now back in action with a new clicker/switch. The desoldering and resoldering process may take some practice, but the result is a fully restored, responsive mouse.
Before reassembling, test the new switch to ensure proper click registration and smooth operation. If everything feels right, reattach the mouse feet pads and screw everything back together.
Enjoy your refreshed mouse!
8 other people completed this guide.
Author
with
Eric S.
401 Reputation
1 Guide authored
5 Guide Comments
Thank you for the guide. How is the click profile of the switches compared to the original?
Carlos - Reply Share
@carlosunch It seems to be close to the original. The replacement switches were meant to be more silent as not to make much noise but it feels very close to the original in my opinion.
Eric S. - Reply Share
Are you sure your mouse is the 'S' version and not the regular 3, as i see some small differences between my 3S and some of your photo's. (.e.g. the extra screw on the bottom, see my previous comment). Furthermore, excellent guide!!!
Chris N. - Reply Share
@chrisn95097 Hi Chris and thanks for the feedback. It's the 3S as can be seen on the step 2 images. The images may not have shown all screws but it's advised to have a narrow enough screwdriver to insert all the way in to unscrew it.
Good guide thanks. No need to dismount wheel or motherboard just to replace left clicker though. Just watch for not burning the mouse case with the side of the iron while soldering. My mouse now clicks better than before and more silently.
Ronan - Reply Share
Past 24 Hours: 230
Past 7 Days: 1,297
Past 30 Days: 5,447
All Time: 17,786
