Introduction
Go to step 1 ↓Over time, zippers tend to wear out. Zippers can eventually separate while closing, causing the slider to unhook from one side of the chain. With this guide, you will be able to fix your zippers quickly and prevent them from wearing out for a while. You will be able to continue to use your favourite items and clothing. It is also a great way to save money! Before starting this guide, make sure your slider is in fairly good shape. If the slider is broken or almost worn out, you will need to replace it.
Tools
Check the opening of the slider to see if it is too wide.
Use the pliers to lightly tighten the slider on each side.
In order to set up the needle and thread, you will need to take about 70 centimetres of thread and pull it halfway through the hole at the bottom of the needle. Make sure both sides of the thread are equal lengths and bring them together.
Tie the loose end of the thread into an overhand knot. This is where you make a loop and pull the thread through it.
4 other people completed this guide.
