Fob watch Battery Replacement
    1. Fob watch Battery Replacement, Battery: step 1, image 1 of 2 Fob watch Battery Replacement, Battery: step 1, image 2 of 2
      • Remove the watch from the silicon casing and turn the watch over.
      • Locate the small indent on the edge of the back plate.
      Ask FixBot
    2. Fob watch Battery Replacement: step 2, image 1 of 3 Fob watch Battery Replacement: step 2, image 2 of 3 Fob watch Battery Replacement: step 2, image 3 of 3
      • Wedge the tip of a Jimmy underneath the indent to lift off the back plate.
      • Use a safe tool to avoid accidents.
      Ask FixBot
    3. Fob watch Battery Replacement: step 3, image 1 of 2 Fob watch Battery Replacement: step 3, image 2 of 2
      • Insert a spudger underneath the white plastic that holds the movement in place.
      • Lift the plastic up and remove.
      • Use an ESD safe tool near the battery or other internal components.
      Ask FixBot
    4. Fob watch Battery Replacement: step 4, image 1 of 2 Fob watch Battery Replacement: step 4, image 2 of 2
      • Locate the small circle battery
      • Wedge the tip of the spudger underneath the small circle battery and lift it out.
      • Do not use a knife or other metal tool with a battery or other internal component as this could cause damage.
      Ask FixBot
    5. Fob watch Battery Replacement: step 5, image 1 of 2 Fob watch Battery Replacement: step 5, image 2 of 2
      • Insert the new SR626SW battery.
      Ask FixBot
To reassemble your watch, follow these instructions in reverse order. Pull out and turn the dial on the side of the watch to adjust the time.
Lilli Morgan
151 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 17
Past 7 Days: 84
Past 30 Days: 317
All Time: 20,279
