This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Logitech MK300 mouse disassembly
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
62
All Time:
492
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide shows you how to disassemble a Logitech MK300 mouse to access its internal components.
    1. Logitech MK300 mouse disassembly, Remove the battery cover: step 1, image 1 of 2 Logitech MK300 mouse disassembly, Remove the battery cover: step 1, image 2 of 2
      • Push the cover towards the back of the mouse.
      • Remove batteries if installed if necessary.
      Ask FixBot
    2. Logitech MK300 mouse disassembly, Remove the Top Part: step 2, image 1 of 3 Logitech MK300 mouse disassembly, Remove the Top Part: step 2, image 2 of 3 Logitech MK300 mouse disassembly, Remove the Top Part: step 2, image 3 of 3
      • Remove the screw using a Phillips screwdriver (size 0).
      • Spread the rear part slightly.
      • Remove the upper assembly (gray and black part) by pushing backward.
      Ask FixBot
    3. Logitech MK300 mouse disassembly, Remove the cover comprising the two buttons: step 3, image 1 of 2 Logitech MK300 mouse disassembly, Remove the cover comprising the two buttons: step 3, image 2 of 2
      • Raise the back of the cover and hold the tab away.
      • Then push forward to remove it.
      Ask FixBot
    4. Logitech MK300 mouse disassembly, Remove the printed circuit board: step 4, image 1 of 1
      • Remove the Phillips 00 screw.
      • Release the card by pressing the tabs.
      Ask FixBot
    5. Logitech MK300 mouse disassembly, Remove the light diffuser: step 5, image 1 of 1
      • Press the pin back using a small screwdriver.
      • Pull the diffuser upwards.
      Ask FixBot
    6. Logitech MK300 mouse disassembly: step 6, image 1 of 3 Logitech MK300 mouse disassembly: step 6, image 2 of 3 Logitech MK300 mouse disassembly: step 6, image 3 of 3
      • Slightly spread the wheel axle fastener bracket.
      • Remove the wheel from the axle bracket.
      • Repeat the operation on the other side of the wheel.
      • Remove the friction spring from the wheel.
      Ask FixBot
    7. Logitech MK300 mouse disassembly, Parts Assemblage.: step 7, image 1 of 1
      • End of guide.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
Juan Garcia is helping us fix the world! Want to contribute?
Start translating ›
Jean-Claude Guinel
279 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 62
All Time: 492
