Logitech MBJ58 Mouse Button Replacement
  1. Logitech MBJ58 Mouse Button Replacement, Mouse button: step 1, image 1 of 1
    • Unfortunately, the left mouse button was 2x "sucked out" (button & the plastic pin over it)
    • Solution: Swap the button on the left with the mouse wheel button and - n small piece of office clip - for reinforcement - melt into the bottom of the pen.
    • YahooOoO - Looift widerer! Addendum: "mouse wheel click" Works by the way also - because there small springs ensure that the button does not "stick" in the pressed state
    • Loosen the Phillips screw in the bottom.
    • The plastic holder of the mouse buttons is loosened by carefully pressing the two plastic closures in the middle.
    • The motherboard is just plugged in and can be carefully removed forwards and upwards.
    • Sensibly, first clean everything (dry).
    • Now click the button for "Links" with the button below the mouse wheel. The solder joints are huge and easy to get even for beginners.
    • Everything should click together again and screws can be screwed back in. -> Loooift.
Repeat the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Tho. Hummet
121 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 13
All Time: 311
