Shop the Holiday Gift Guide
Logitech M325 Scroll Wheel Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
7
Past 7 Days:
57
Past 30 Days:
214
All Time:
1,383
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If your Logitech M325 mouse scroll wheel is unresponsive, damaged, or behaving unpredictably, this guide will help to replace your scroll wheel. The scroll wheel is a part of the mouse which allows the user to scroll through windows, navigate backwards, navigate forwards and use the middle click button. If one of these functions do not work, your scroll wheel is most likely damaged.
Parts
Tools
  • Spudger
    4.9
    Optional
  • Tweezers
    Optional
  • Phillips #0 Screwdriver
    5
    1. Logitech M325 Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 1
      • Caution: Before you begin, ensure that the mouse is powered off (red color displayed on the switch). The switch can be found at the bottom of the mouse.
      • Remove the battery cover from the bottom of the mouse by sliding downwards.
      Ask FixBot
    2. Logitech M325 Scroll Wheel Replacement: step 2, image 1 of 2 Logitech M325 Scroll Wheel Replacement: step 2, image 2 of 2
      • Lift out the AA battery.
      • Remove the USB adapter.
      Ask FixBot
    3. Logitech M325 Scroll Wheel Replacement: step 3, image 1 of 1
      • Peel off the sticker in the battery compartment to reveal the screw underneath.
      Ask FixBot
    4. Logitech M325 Scroll Wheel Replacement: step 4, image 1 of 2 Logitech M325 Scroll Wheel Replacement: step 4, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the 5 mm screw in the battery compartment.
      Ask FixBot
    5. Logitech M325 Scroll Wheel Replacement: step 5, image 1 of 2 Logitech M325 Scroll Wheel Replacement: step 5, image 2 of 2
      • Slide the lower case downwards and separate the top case from the main mouse body by lifting it off.
      Ask FixBot
    6. Logitech M325 Scroll Wheel Replacement: step 6, image 1 of 2 Logitech M325 Scroll Wheel Replacement: step 6, image 2 of 2
      • Use a pry tool to unclip the scroll wheel from the PCB by pushing the clip out of the holder.
      • Remove the scroll wheel by lifting it up.
      Ask FixBot
    7. Logitech M325 Scroll Wheel Replacement: step 7, image 1 of 2 Logitech M325 Scroll Wheel Replacement: step 7, image 2 of 2
      • Align the replacement in the same position as the old scroll wheel.
      • Push down and clip in the scroll wheel.
      Ask FixBot
    8. Logitech M325 Scroll Wheel Replacement: step 8, image 1 of 3 Logitech M325 Scroll Wheel Replacement: step 8, image 2 of 3 Logitech M325 Scroll Wheel Replacement: step 8, image 3 of 3
      • Align the top housing clips with the mouse body clip openings.
      • Slide top housing back onto mouse by pushing it in.
      Ask FixBot
To reassemble your device, follow steps 1-4 in reverse order.
2 other people completed this guide.
Author
with
mykayat_YU
175 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 57
Past 30 Days: 214
All Time: 1,383
