Up to 20% off select tools
Logitech K480 Keycap Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
31
Past 30 Days:
119
All Time:
1,128
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your Logitech K480 keyboard is missing a keycap or if it's damaged, you can follow this guide to replace it. Replacing keycaps on rubber dome keyboards can be confusing but these steps are easy for anyone to follow. Keycaps cover the buttons that actually register what you're typing. They provide a more comfortable way to type and can also allow for customization.
    1. Logitech K480 Keycap Replacement, Back Cover: step 1, image 1 of 1
      • Flip the keyboard over.
      Ask FixBot
    2. Logitech K480 Keycap Replacement: step 2, image 1 of 3 Logitech K480 Keycap Replacement: step 2, image 2 of 3 Logitech K480 Keycap Replacement: step 2, image 3 of 3
      • Remove the four rubber feet with a spudger.
      Ask FixBot
    3. Logitech K480 Keycap Replacement: step 3, image 1 of 3 Logitech K480 Keycap Replacement: step 3, image 2 of 3 Logitech K480 Keycap Replacement: step 3, image 3 of 3
      • Slide open battery panel.
      • Remove the batteries.
      Ask FixBot
    4. Logitech K480 Keycap Replacement: step 4, image 1 of 2 Logitech K480 Keycap Replacement: step 4, image 2 of 2
      • Remove the three 4 mm screws under the rubber feet using a Phillips #0 screwdriver.
      Ask FixBot
    5. Logitech K480 Keycap Replacement: step 5, image 1 of 2 Logitech K480 Keycap Replacement: step 5, image 2 of 2
      • Remove the two 4 mm screws from beneath the battery cover using a Phillips #0 screwdriver.
      Ask FixBot
    6. Logitech K480 Keycap Replacement: step 6, image 1 of 3 Logitech K480 Keycap Replacement: step 6, image 2 of 3 Logitech K480 Keycap Replacement: step 6, image 3 of 3
      • Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
      • Slide a blue pick in to keep the pieces apart while you work on other areas.
      • Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
      • The loud snaps are the clips that hold the pieces together. They're not breaking and you do not need to be alarmed.
      Ask FixBot
    1. Logitech K480 Keycap Replacement, Metal Plate: step 7, image 1 of 3 Logitech K480 Keycap Replacement, Metal Plate: step 7, image 2 of 3 Logitech K480 Keycap Replacement, Metal Plate: step 7, image 3 of 3
      • Remove the eight 3 mm screws using a Phillips #00 screwdriver
      • Remove the five 2 mm silver screws from the metal plate using a Phillips #00 screwdriver.
      • Remove the single 4 mm black screw by the motherboard using a Phillips #00 screwdriver.
      Ask FixBot
    2. Logitech K480 Keycap Replacement: step 8, image 1 of 2 Logitech K480 Keycap Replacement: step 8, image 2 of 2
      • Lift up and remove the metal plate.
      Ask FixBot
    1. Logitech K480 Keycap Replacement, Keycap: step 9, image 1 of 1
      • Flip the flex circuit and rubber dome sheet over.
      Ask FixBot
    2. Logitech K480 Keycap Replacement: step 10, image 1 of 3 Logitech K480 Keycap Replacement: step 10, image 2 of 3 Logitech K480 Keycap Replacement: step 10, image 3 of 3
      • Using the spudger, gently press on the underside of the key and pop it out.
      Ask FixBot
Author
with
Madison
778 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 31
Past 30 Days: 119
All Time: 1,128
